My new 2.3tl's powered by Sansui B2101..Yikes
amb426amb1
amb426amb1 Posts: 148
edited March 2014 in Vintage Speakers
After 2.3tl purchase I started sorting the sound at my shop were I have a B2101 amp. Went thru SDA handbook and completed initial steps with all the individual speakers and SDA left/right sounding present. Moved on to powering with music and met with.....actual unbelievably great sound. Never gave any thought to the common neg. ground issue. Have logged a few hours on them with this balanced non-common ground amp with good results. I then started thinking more about the Sansui and quickly determined it was sadly not compatible with SDA. Glad I didn't blow the speakers or the amp for that matter! I did notice the positives of the amp were hooked? Don't know if that saved the components or what.
Post edited by amb426amb1 on
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Glad to there was no damage!
    amb426amb1 wrote: »
    What do you mean by this? Two positives should never be hooked together as you'll blow your amp.
  • amb426amb1
    edited March 2014
    zingo wrote: »
    I'll check later today but I swear when I tested the positives there was zero resistance.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited March 2014
  • Schurkey
    Schurkey Posts: 2,122
    edited March 2014
    amb426amb1 wrote: »
    More likely zero continuity, infinite resistance. On my meter, that's indicated by "OL" on the digital readout. Other meters may be different.
  • amb426amb1
    edited March 2014
    Don't know what I was thinking late last night when I figured out the AMP was a balanced design that has no common ground but the positives absolutely have no continuity between them. Cant believe I didn't put 2&2 together as I set DC offset bias on this AMP two years ago which was not fun with this model as it basically is 2 AMPS providing left/right power separately.
