What's the max temperature should .....
polk500
polk500 Posts: 1,171
edited January 2014 in Electronics
Good day,
So I have all my equipment in a 5'x5x8' high room.
The components are sitting on heavy duty plastic shelves with plenty of holes for ventilation and are stacked with about 12" of space between each component.
As I'm running 3 amps and a AVR The temperature get to a max of 90 degrees in the room. I have a small fan under the stand blowing up to move air.
So the question is should I vent the room outside (it would be a pain in the butt but doable)
Now I don't think it's a problem as the BK runs hotter then 90 F not sure the exact temp. The digital gage I use only goes to 120 F
But I figured I would get some input from you guys.
Roger
Post edited by polk500 on
  • zane77
    zane77 Posts: 1,696
    edited October 2013
    I'm a huge fan of keeping the temperature as low as feasible (70 degrees). All of the medical imaging equipment I work on, one of the biggest problems is overheating. We have monitors on the equipment that checks the equipment 24/7 to make sure we don't run into any heat issues. The temperature may be 90 externally but how high is it internally?
    Two Channel
  • Speedskater
    Speedskater Posts: 495
    edited October 2013
    The inside of your parked car gets way hotter than that (90F) on a sunny day. Some listening rooms get hotter than that every summer. Sunshine through a window can heat an amp hotter than that.
    Is the free air just above (say an inch or three) your components 90F or 120F ?
  • polk500
    edited October 2013
    Thanks for the replies. I do appreciate the fact that the medical equipment needs to stay at 70. The BK runs hotter then 120 on top of the chassis how much I'm not sure as I had mentioned the gage I'm using only goes up to 120 so using the same logic if the ambient temperature is no greater then what the internal temperature is then I shouldn't have any problems.
    As I have the fan on the floor (concrete floor) blown up over the equipment the gage resister 90 max at the 6 foot level. So I think even if say I vented the air outside I don't think I could drop the temp much. Even when the amps were in the glass racks in the living room you could feel the heat.
    Cheers
    Roger
    F1nut Posts: 52,018
    edited October 2013
    Ummm....air conditioning.
  • polk500
    edited October 2013
    Yes that would work. But the wife would be pissed if I did and didn't put it in the rest of the house.
    Don't do AC much in the frozen north. Probably only need it for a couple of weeks at most.
    Cheers
    Roger
  • Phasewolf
    Phasewolf Posts: 514
    edited October 2013
    Your going to dry out the cap in the amps quicker if they are in a hot environment vs a cool one. I would aim to keep it 70 to 75 but that is just me and the fact that I hate replacing caps.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
    edited October 2013
    Roger,
    90 isn't that hot to begin with and you already have a fan. No need to vent outside but given your location why not just leave the door open an inch or 2 ? You can also just cut a nice square hole at the top and just use a return vent cover or any vent cover to let air out.
  • jimsvm
    jimsvm Posts: 307
    edited October 2013
    Ductless ac or heat pump version. Heat pump built for running in lower ambiant conditions. Cheers.
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • polk500
    edited October 2013
    tonyb wrote: »
    Roger,
    Thanks for the replies,
    That's what I done on the weekend.
    Well I cut out two holes (6" x 10") one at floor level and one at the eight foot level and build a small shelve to place another small fan on.Warm air is exhausted out into the stairwell (as well as noise from the fan) and the vent covers look like they were always there.
    As for the temperature;I was playing some tunes for a few hours and watched a movie on Sunday and it was between 78 and 80 degrees so not to bad.
    And it costed me $38.00 and a couple of hours with driving to the hardware store and cutting out the openings.
    Now I've got to figure out how to turn on the fan with my remote as right now I have to plug and unplug it.
    Cheers
    Roger
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited October 2013
    Those fans draw little enough power that you may be able to run them from a switched outlet on other gear like an avr
  • polk500
    edited October 2013
    Hey good idea I will check it out when I get home and see does it work.
    Roger
  • polk500
    edited January 2014
    Well looks like I blew a fuse or something in my Harman Kardon 3600 switched AC outlet that i use to run a small fan. It was working fine up till last evening or maybe earlier as I don't go into the room everyday.
    I read the manual and can't find anything referencing a fuse but one would think that there must be correct?
    So my question; Is it a big deal to open one these AVR up and have a look and if I was what would I be looking for a glass tube type fuse?
    Not a electronic's guy but its probably pretty easy and I don't like to spend money on something that's probably a easy fix.
    Thanks for any suggestion.
    Cheers
    Roger
  • Speedskater
    edited January 2014
    Did you try plugging a little light or something into that receptacle?
  • polk500
    edited January 2014
    Yes I did.
    Roger
  • polk500
    edited January 2014
    I should mention I've call Harman Kardon left a message 4 hours ago no response as of yet.
    Roger
  • polk500
    edited January 2014
    So as a follow up HK returned my call and said it was fused switch and he said it was buried deep(?) inside; and didn't recommend opening the AVR to fix it unless I was a experienced tech.
    I will probably just leave the fan on all the time as it draws very little power and it is quiet.
    Or maybe not cuz it will just bug the #hit out of me knowing something is not working!!
    Well got a weekend project and if I can't fix it at least I will get a look inside of the unit.
    Cheers
    Roger
  • Tornado Red
    Tornado Red Posts: 939
    edited January 2014
  • polk500
    edited January 2014
    And then there's the clapper if wasn't so ugly.....
    Thanks for the laugh
    Roger
  • polk500
    As an update to this thread, I when with a fan from the coolerguys, it's controlled thermostatically so I have it set at 75 degrees works great.
    I read about it on this site but I can't remember who started the thread.
    Anyhoo thanks.
    Roger
