lost the bi-amp jumpers - Polk Monitor 70's
Tardcore
Tardcore Posts: 11
edited May 2013 in Speakers
So I used to have my Monitor 70's bi-amped and I stashed the jumpers away someplace "safe".
I just bought a new amp/new cables and need to go with a single-amp setup.
Needless to say, I have no clue what I did with them and I have no idea where I can get some replacements.
Any leads on where I could purchase jumpers?
Post edited by Tardcore on
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Just make a new set, it's really easy, or you can find them on ebay or I believe any of the cable sites monprice bluejeans etc
    Two Channel
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2013
    regular old speaker wire is suppose to be an upgrade over the factory strap metal jumpers.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Tardcore
    Tardcore Posts: 11
    edited May 2013
    Thanks! I didn't know I could just cut a small piece of wire to do the job instead.
    F1nut Posts: 51,805
    edited May 2013
    Yep, some high quality wire is far better than the straps.
  • B Run
    B Run Posts: 1,888
    edited May 2013
    Yeah I "lose" mine on purpose and just put some good quality cable, preferably the ones you're using in your system. I had to dig mine back when I sold my RF82's because the guy didn't want the Kimber Kable jumpers I made :rolleyes:
  • Tardcore
    Tardcore Posts: 11
    edited May 2013
    thanks again for the quick responses.
    I wired short 4" pieces into terminal with just bare wire. I think it will do the job.
    I guess if I wanted to do it right, I would need to get some spade/banana connectors.
  • B Run
    B Run Posts: 1,888
    edited May 2013
    Tardcore wrote: »
    Never hurts to add them, always a good project for when you're bored but not necessary to get the job done. Did you notice any difference?
  • Tardcore
    Tardcore Posts: 11
    edited May 2013
    Well, these speakers were originally part of a HT setup, but I have had them in storage for a year or two--had to scale back the HT due to space issues.
    I recently moved and got a good deal on a Marantz PM5004 ($185 Amazon Warehouse), so I dug the M70s out of storage to use in a stereo setup.
    long story short--I don't really recall what they USED to sound like.
    HOWEVER, I am liking the sound now. The Marantz is only 35 watts and I feel like the sound is missing a little "oompf" but it's a small room, I am no audiophile, and the price was right.
  • B Run
    B Run Posts: 1,888
    edited May 2013
    Right on. That's a good deal on the Marantz for sure, the 70's do like power though
  • Bob in WI
    Bob in WI Posts: 155
    edited May 2013
    They sounded awful nice powered by a 100wpc NAD receiver. Seemed pretty efficient tho/ 35wpc should get you going nicely. Enjoy.
