SDA 1's blowing 1a fuses?
newby
I just purchased these.
The previous owner says he found them blown.
I get to enjoy them for awhile, the discover one or both fuse gone?
I drive them w/ a Bryston 4b st.
Post edited by newby on
You need to ask a specific question here - can't tell what you want :question:"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Are you talking about the poly switches for the tweeters?Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
The 1A fuses for both speakers keep blowing?
I assume they are for the tweaters? -
I am hoping to discover if there are other caises to blown fuses than over driving the speakers.
Thx. -
I discovered by reading here that these speakers of mine are SDA 1A signature model.
You talk about overdriving the speakers, just how loud are you playing these when the fuse blows? If you play them at a moderate level is there any sign of distortion coming from the speakers?
If you list the equipment you are using to drive these speakers that would help us to help you."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
IIRC, that is a dual mono amp and you cannot use dual mono, mono block or non-common ground amps with your speakers.Political Correctness'.........defined
President of Club Polk -
The 4B ST is common ground,with the grounds already strapped internally,so SDA safe.
I didn't recall correctly, thanks.Political Correctness'.........defined
You're blowing 1 amp fuses in your 1A Signature speakers?
Is 1 amp the correct rating for that fuse? Are they fast-blow or slow-blow fuses? Do you have the correct kind?
"I" would re-cap the crossover, and test the tweeters along with the other drivers, and verify the wiring isn't screwed up. The OEM caps are long past their expected service life anyway. Wouldn't surprise me that defective caps, or defective tweeters are the primary cause of the fuse problems IF (big IF) you're using the correct fuses. -
1 amp fast blow is the fuse specified here in this forum. I buy the fuses at the hardware store?
Are there more specific fuses needed?
I am curious how to test the tweeters? As I said earlier, they play for awhile before blowing.
I tend to play the volume level where the mid drivers are just beginning to move.
Thanks for the assistance. -
Probably not.1 amp fast blow is the fuse specified here in this forum. I buy the fuses at the hardware store?
I'd connect 'em to an ohmmeter. Should be "about" 6 ohms, I'm thinking. That's by no means a conclusive test...but it's simple and easy.I am curious how to test the tweeters? As I said earlier, they play for awhile before blowing.
Less than 1/4 of a watt should make the mid-woofers move. Are you saying the mid-woofers don't work unless the volume is turned up? How are you judging "movement"? By eye or by feel or by sound?I tend to play the volume level where the mid drivers are just beginning to move.
Your amp outputs something like 200--250 watts into 8 ohms; and is known for quality. Those speakers should be able to accept more power than that on peaks. Unless you're playing loud as hell, there's something wrong. Possible defective amp???
If the crossovers in the speakers haven't been rebuilt, they're known defective. Service life expired about a decade ago--or more.
Do you still pop fuses if the SDA interconnect cable is disconnected?
