Think I'm Gonna Try This
deronb1
This item looks really interesting. Not much money and cool looking!
http://www.ebay.com/itm/MK3A-Indeed-Hi-Fi-Class-A-Valve-Buffer-Amp-Amplifier-NOS-5814A-tube-USA-sixties-/251016465447?pt=Vintage_Electronics_R2&hash=item3a71bf4c27
Post edited by deronb1 on
So basically, it just piggy-backs a tube into your signal chain? Less is more, IMO.
Monster AVL-300, HTS-2500 MKII -
If it warms up the sound a bit, I am all for it. Will post a review.
Have you ordered it yet or still thinking on it ? Looking forward to review.
ordered it last night.
Cool. Where do you plan on putting it ?
between the pre and the amp. Can get the TT in on the action too! :cheesygrin: -
Looking forward to your thoughts on it. May want to join ya.
I'm looking forward to it too. Will certainly let you know.
Interesting - looking forward to your review. Looks like it uses quality parts, though the power supply is a little cheesy. Could it be the first mod ? :cool:"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Love the performance of well designed and well implemented vacuum tube amplification circuitry for audio. Hate the gratitous use of a vacuum tube, in effect, as a distortion generator to "add warmth".
Just my hardly-humble opinion, of course. YMMV. -
mhardy6647 wrote: »Love the performance of well designed and well implemented vacuum tube amplification circuitry for audio. Hate the gratitous use of a vacuum tube, in effect, as a distortion generator to "add warmth".
This is not a well designed, well implemented circuit. Plus it's run off a switching walwart power supply, not the best.
Not to rain on the OP's parade but you would have been much better off spending a bit more stateside and getting the Yaqin CD3 buffer.
I have the 12au7 version of this little headphone amp for work:
http://headfonics.com/2012/01/bravo-audio-headphone-amp-series-part-1-the-v1-2/
Indeed (maker of the above tube buffer) makes one very similar.
I like it, and it was worth the small investment for low volume listening at work, but i probably wouldn't buy it again.
However, I'm with mhardy, and struggle to understand the point of a tube buffer. IMHO, either you like the sound of your current gear, and don't need to "warm it up," or you need to try different (possible tube-based) gear.
Nevertheless, if this makes deronb1's rig sound better to his ears, then I say "awesome!" -
there are good reasons to use a buffer -they're designed to match impedances between components. As such, a good buffer is designed to be unity gain and utterly distortionless - to add or subtract nothing (in amplitude, phase, or frequency domains) to the signal. Improving the impedance match, e.g., between a preamp and power amp could certainly have audible consequences (flattening of frequency response, e.g.)... the problem is, I think, that some of these tube buffers are deliberately designed not to be benign. That's the reason I get persnickety about the topic.
PAiA's "Tubehead" is a good example, I think :-)
... and, at least, they're honest about it!
http://www.paia.com/proddetail.asp?prod=9305HSR
http://www.paia.com/proddetail.asp?prod=9305KEN -
Yeah, I'm curious too. I've seen lots of these things but all from China. This is a hobby, and the price isn't much so you have something to experiment with that doesn't permanently do any changes.
I just recieved a cmoy kit from Australia. I know there are MUCH better ones here, but as it is an experimentation to see if it really helps with headphones if I don't like it much, I am not out much money. If it helps, I may be more inclined to spend money on better stuff stateside with better electronics.
Looking for your review man! I think it takes a couple of weeks or so to come from China and through customs.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
What is a 'warm' sound?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
And the pitch goes wide!
My response was merely a flippant, vague comment to mirror the vague comment of "warm".
Simply adding tubes in-line in a rig won't necessarily automatically mean a "warmer" sound. More to it than that.
I used an inexpensive Grant Fidelity tube buffer for a year or two before I found a resonably priced tube pre. Made the sound sweeter and more natural. Hooked me on tube equipment.
You can switch the buffer on and off, and I always thought it sounded better with it on. Changed/upgraded tubes a few times and it sounded even better.
I know I liked it because 3 or 4 times I would headed to the basement for some listening and thought things sounded OK but not great. Each time it was because I forgot to turn the tube buffer on. Flipped it on and the magic returned.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
When I think of warm sound, I think of a late-1950s hifi console or a Dynaco ST-70 in its stock configuration - rolled off at both ends of the frequency spectrum, slow and thick sounding, but relaxed, mellow and unprovocative. I like to call that rather syrupy sound "boozy and bluesy".
At their best, vacuum tube amplifiers deliver convincingly real sound; like the instruments or vocalists are in the room.
(so can solid state amplifiers, but dollar for dollar, it's easier to get to with vacuum tubes IME)
The little interstage add-ons can deliver the former; I don't think they can reasonably be expected to deliver the latter. -
mhardy6647 wrote: »When I think of warm sound, I think of a late-1950s hifi console or a Dynaco ST-70 in its stock configuration - rolled off at both ends of the frequency spectrum, slow and thick sounding, but relaxed, mellow and unprovocative. I like to call that rather syrupy sound "boozy and bluesy".
I'll have some "pancakes" with that. These old ears love that effect and pancakes too! lol
There's only one way for the OP to find out...give it a try. I really like the Yagin Tube Buffer in my system.
Agree with you....My Yaqin was $50 more than what he paid for the Indeed G3....Much better tubes and it has it's own power supply.I have the Indeed G3,also......I got on auction on ebay for $46 +$20s/h=$66.It has the same 5814A tube.....I just use it as a buffer....sucks,compared to the CD3.......My plan has always been to use a tube buffer until I can get the Dared pre,like Brock has,and then really go down the tube rabbit-hole(lol)........peter -
This is the buffer I use. It's "nice" on some material, get's "in the way" on other. I love the glowing terms that are used to describe it though!
GOT SYRUP ????
MUSICAL FIDELITY X-10 V3 MU-VISTA TUBE BUFFER
A legend returns! Musical Fidelity sold almost 50,000 of their original X-10 Tube Buffer Stage and has finally brought it back to life. The new X-10v3 is based on the Musical Fidelity exclusive Mu-Vista (kW) tubes and is guaranteed to add the magic of tubes to any system without adding any significant noise or distortion. The new Mu-Vista tube is Musical Fidelity?s highest performance tube to date. It?s more linear and quieter, with better performance capabilities than either their highly regarded Nu-Vista or Tri-Vista tubes. The X-10v3 is a tube output stage that can be added to any system; perfect behind any digital player, in a tape monitor loop or between your preamp and amp. Turn your CD or any other affordable digital player into the tube-hybrid player of your dreams. Add it between your amp and preamp or into a processor or tape loop and hear every single source component come to life in a spectacular way. Once in place, you will hear an added level of richness, warmth and musicality previously attainable only with a tremendous investment in world-class tube gear. The $399 Musical Fidelity X-10v3 Tube Buffer Stage will be a very limited manufacturing run, so audition one in your system before they are history!
About the Mu-Vista tube:
Musical Fidelity's latest discovery, the 6112, is an ultra high performance twin triode that we call the mu-Vista. Originally, it was used by the US military for crucial low noise guidance and other missile functions. It is incredibly rugged and immune from microphony and other extraneous effects. Also, and we hope this attribute is never needed; it's immune from electro-magnetic pulse (EMP) which occurs when a nuclear bomb explodes! As you would expect, the mu-Vista is super tough, super quiet, ultra reliable, incredibly linear and absolutely predictable.
Musical Fidelity has not had a single Tri-Vistor 5703 tube fail anywhere in the world in any of their Tri-Vista products. Our tests show that the mu-Vista has similar levels of reliability, and why not? The tubes have been purchased direct from the US military and are genuine milspec, mil usage parts.
As far as we know, they have bought the vast majority of the world's stock of the amazing mu-Vista. It will form the basis of a number of limited edition products.
Recommended Usage:
* On the output of a CD player.
* In the tape loop of an integrated amplifier.
* Between a pre and power amp.
* From the front two channels of your HT processor or receiver
Features & Benefits
* High input impedance - Does not offer any loading to the source CD player and as a result it gives its best possible performance.
* Low output impedance - Drives any amplifier easily and ensures virtually perfect linearity.
* Uses exclusive mu-vista (6112) mil-spec mil-usage tube- Excellent technical performance, incredible longevity - great sound.
* Low noise, low distortion, huge overload margin and wide bandwidth - Extremely clean sound with huge dynamic range.
* Limited edition - Not many other people will have one of these babies. -
I was kicking around the Yaquin stuff and I am not expecting miracles here fellas. Just want to see if there is a holistic change in the sound that leans it more toward the warm side. It's hard to describe a desirable sound with words, so I am just gonna stick with that. I know what I mean dambit!:cheesygrin: Anyway, like most of you have pointed out, there is a notible change for the better with the use of these units. I have no doubt that each system would experience it's own change with adding ANY item and I am at the point with my 2ch system now for very subtle changes (hopefully for the better).
Great replies and I hope to get this sucker hooked up soon. I do have the sinking feeling, like somone mentioned, that I am going to like the change and want to improve it further. Aaaaaaaaaaaaaaaaaaaaa! (me falling down the rabbit hole)
