LSi 15's on the way!
mesquitehead
mesquitehead Posts: 312
edited January 2014 in Speakers
Just spoke with Jessica at polk and ordered my LSi 15's (ebony), should be here by the end of the week! Going to run them on my TFM-35 via the pre-outs on my Yamaha RX-A820. Looking forward to doing the woofer upgrade asap. Thanks again for all those who provided helpful input in making my new speaker choice.:cheesygrin:
"Thats great... but how does it sound"
http://www.burginmcdaniel.com/
http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
2007 Tundra 5.7 TRD DC
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce
Post edited by mesquitehead on
  • stretchl
    stretchl Posts: 1,334
    edited August 2012
    I'll be very interested in following the woofer upgrade.
    Enjoy!
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
    EndersShadow Posts: 17,696
    edited August 2012
    stretchl wrote: »
    Enjoy!
    There is a thread about it here that gives you all the details you need
  • mesquitehead
    edited August 2012
    Yes there is , just do a search and you will find it. The woofer you want is the Polk DB840 (single voice coil), pretty much a drop in, the trick is getting the speaker grills off and making sure you get the woofers sealed well and use better screws when you install them. AMazon has the woofers for $57 each currently.
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • stretchl
    edited August 2012
    Cool.
    Hit us up with a before/after evaluation!
    - Isaac Asimov
    Hi-Fi
    Visuals
    edited August 2012
    The thread is linked in my comment but here is the direct link too: http://www.polkaudio.com/forums/showthread.php?89529-DB840-sub-in-LSI15-s-replace-the-stock-8-quot-driver!!!!!&highlight=db840
  • stretchl
    edited August 2012
    Thanks, Dan. Awesome thread.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • mesquitehead
    edited August 2012
    Thanks Dan!:cool:
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • VTO888
    VTO888 Posts: 72
    edited August 2012
    Congrats. Been wanting to do the db840 upgrade for awhile and haven't pulled the trigger. I think I better order the subs before they disappear. Knowing my luck. $50+ on amazon as well.
  • mesquitehead
    edited August 2012
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
    edited August 2012
    I personally wouldnt venture outside what is recommended by Polk engineers myself.
    Also as an FYI, while your in there you might want to dynamat the port tube as well as its just cardboard.
  • stretchl
    edited August 2012
    Can u pls elaborate on this a bit, Dan?
    - Isaac Asimov
    Hi-Fi
    Visuals
  • mesquitehead
    edited August 2012
    Just so happens I have a case of Dynamat Extreme left over from my truck install. Thanks for the heads up!
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • hochpt21
    hochpt21 Posts: 5,423
    edited August 2012
    VTO888 wrote: »
    I'm another in the camp of waiting to pull the trigger. More worried about messing something up as I've never opened a speaker before, but the thread makes it seem easy.
    I would probably dynamat also, just now sure where it goes or how much to get?
  • mesquitehead
    edited August 2012
    Easy, you just cut it and stick it around the port, it's kinda like a thick tape with a rubber layer under the foil side. SOme also suggest adding it to the woofer frame as well. Any local car audio shop should have enough scraps of it to give away for free or I'll be glad to send you some.
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • hochpt21
    edited August 2012
    Thanks for the offer. I'll check around locally when I get the subs.
    edited August 2012
    Most important part is that you wrap it around the OUTSIDE of the port, not the inside (which would restrict the diameter of it :wink:). Its a ridiculously easy product to use.
    The woofer upgrade is very easy, hardest part is going slow to get the grill off without scratching or flaking the wood vener on the panel.
  • mesquitehead
    edited August 2012
    Lsi 15's arrived today in fine shape except for one pair of missing feet which Polk says they will send me if they have any (backorder). Got them hooked up to the HT system via the Yamaha RX-A820 and running power off the Carver M-1.0t, they sound great so far. Between my kids football game, Radney Foster concert tonight, University of Texas season opener tomorrow (Hook'em) and other commitments it looks like Sunday will be my first chance to really tinker with them. Dire Straits/Dire Straits was the first disc I played on them and it was sweet. Thanks for the tips and advice amigos, have a great holiday weekend!
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • stretchl
    edited August 2012
    Awesome :exclaim:
    - Isaac Asimov
    Hi-Fi
    Visuals
  • stretchl
    edited September 2012
    Just ordered the subs off Amazon.
    Looking forward to this...
    - Isaac Asimov
    Hi-Fi
    Visuals
  • mesquitehead
    Let the woofer upgrade begin!
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • Drapolas
    Drapolas Posts: 12
    edited December 2012
    I just got a pair of LSi15s from Polk Audio Direct. They are really great, and was wondering if the db840 upgrade is really worth it. Your thoughts will be appreciated. Thanks!
  • xftman
    xftman Posts: 153
    Drapolas wrote: »
    +1. I got my pair Lsi15 (Cherry) delivered today.
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • PSOVLSK
    PSOVLSK Posts: 5,372
    Drapolas wrote: »
    In a word, YES!
    Try Crutchfield. They often have buy one, get one 1/2 price. It's super easy to install and it really adds to the low end. It's not going to be like you added a subwoofer or anything, but it's a little bit tighter, deeper bass. Not a night and day difference, but noticeable.
  • slider2828
    slider2828 Posts: 118
    Wow great setup!!! What were you coming from?
  • jtshaw43
    jtshaw43 Posts: 161
    I hope you enjoy your new 15's dude...
  • a99
    a99 Posts: 1
    edited January 2014
    hello mesquitehead
    i read some of your old post regarding choosing between yamaha vs other avr sorry im asking you a different question other than the recent subject but i found ths one is your recent one so sending you here well i ve got monitor 70 series ii and cs 2 and bic f12 and boss for rear now i want to choose between yamaha rx v 775 wa series or rx a 820 series
    thanks
