'06 Honda Pilot Serpentine Belt.....
kevhed72
kevhed72 Posts: 5,073
edited August 2012 in The Clubhouse
The repair shop wanted 125.00 to replace this due it is worn/cracked a bit. Is this something I can do if I just pick up a new belt and install myself....it APPEARS pretty straightforward, but I hate to assume:question:
Post edited by kevhed72 on
  • sda2mike
    sda2mike Posts: 3,131
    edited August 2012
    125? sounds low..get a written estimate
  • zingo
    zingo Posts: 11,258
    edited August 2012
    sda2mike wrote: »
    Agreed. That seems like a REALLY good price.
  • kevhed72
    edited August 2012
    Maybe the price was just for the belt and no labor....not sure.
    Anyhow, I did a quick search on how to do this yourself and words like "torque wrench" and "ft. lbs. of pressure" came up....I think I will leave this to the professionals.
  • nspindel
    nspindel Posts: 5,343
    edited August 2012
    The serpentine belt went on my wife's jeep, and that was pretty much the end of her jeep. My advice, let the pros do this one.
  • gdb
    gdb Posts: 6,012
    edited August 2012
    Can't say what's involved w/Hondas but, approx 30-45 seconds will be long enough to change the S. belt on millions of GM vehicles due to their super simple, spring loaded tensioning device. My vintage Bonneville requires only an 18 mm socket and a breaker bar or ratchet to relieve the tensioner pulley. I'd bet that there's probably at least 3 vids on youtube showing how the Honda belt is done and.......$125.00 is an awfully big fee for a simple non-timing belt change IMO.:wink:
  • shawn474
    shawn474 Posts: 3,052
    edited August 2012
    If $125 is for the belt and labor, I say let the pros do it. Might seems easy and straightforward but if you have never done it before and are going by a youtube video, I wouldn't risk it. If that slips off or is installed wrong, it can mean major damage to the car.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • strider
    strider Posts: 2,568
    edited August 2012
    That is a good price, FWIW. We'd charge $125 in labor alone for drive belt(s) on a Hyundai.
    Wristwatch--->Crisco
  • Drenis
    Drenis Posts: 2,871
    edited August 2012
    I'll change it for $20 and a case of beer. :cheesygrin: You can help me drink the case.
  • JuanR
    JuanR Posts: 718
    edited August 2012
    Drenis wrote: »
    Make sure you change the belt first and then drink the beer..not vice versa...LOL!
  • madmax
    madmax Posts: 12,434
    edited August 2012
    I've always found that things like this are easier than you may think. Give it a try and if you get stuck then put it back together and take it to someone. Like some old movie says "if you can't fix it yourself then its not really yours".
    BTW, I always drink the beer first. :)
    Vinyl, the final frontier...
  • jbooker82
    jbooker82 Posts: 1,627
    edited August 2012
    madmax wrote: »
    Yea but some time they are not. I dont know the specifics of the honda pilot but my wifes Volvo XC90 was a pain. The crank pully had a big disk bolted to it. You cannot get the belt around it with out unbolting it. In order to get at it you have to take the passanger front tire, and inner fender well out. Then the spring load tensioner required a specail volvo torx wrench. There isnt enough room to get a normal torx bit and ratchet between the spring loaded tensioner and the unibody / car frame.
    I put the new serpentien belt on while I had it tore appart for the 125k mile timing belt and water pump replacement. So the inner fender and front tire had to come off any way, but I would have been pretty frustrated if I was doing just the serpentien belt in the drive way. I threw the old belt away because there is no way your going use the old one on the side of the road for an emergency.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    tonyb Posts: 33,019
    edited August 2012
    For that coin, let the pro's do it. Here in Chicago, that would just take care of labor costs. Plus if it breaks down the road, you have someone to blame. :wink:
  • drumminman
    drumminman Posts: 3,396
    edited August 2012
    I'd do a bit of research, including watching the you tube video. Check on the tools needed vs. what you have on hand. You'll get a sense of whether or not it's outside your capabilities.
    If it were me it'd be tough to decide without a bit more information.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited August 2012
    suggest to purchase the OEM Honda belt.
    could have issue with aftermarket replacements.
