need helpful tips on sda2b's maintaining them etc
boston1450
boston1450 Posts: 7,758
edited May 2012 in Vintage Speakers
hello all. i am asking for helpful tips on maintaining my sda2b's. i polish the tops every other day and i probably should find out what else i should be doing. is there things i should do to maintain the drivers. to keep them from drying or things like that. ive never had issues with others speakers ive owned,but dont want too also.i got them awhile ago from original owner who stated they hadnt been used much. . i thought this would be the place to ask.what work good for cleaning/polishing/maintaining inside and things like that. thanks for any tips
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
    edited May 2012
    You polish them, every day? Really?
    Mine have been in storage for a few months, haven't done a thing to them.
    Firstly, the surrounds are rubber so you don't have to do much there. You might want to open them up, get some JB weld and spot expoxy the mid-drivers in three or more spots so that your magnets don't ever shift or fall off. A problem often seen when "moving" or trying to ship SDAs.
    Other than that. You can search for the usual; crossover upgrades and replacing caps, etc. Checking the integrity of the air seal and using mortite or something else. Many use dynamat on the passive and other speaker baskets, and so on.
    Oh, and if you don't have the new RD-019X replacement tweeters. That is, if you're still running SL-2000 or 2500s, etc. You might want to call Polk and get those newer drop in silk dome tweeter replacements!
    With SDAs it's NOT so much about their exterior (although people do treat that--I don't) it's more about keeping up the interior which is more important for "how" they sound.
    Having said that, I should point out that I am "notoriously" lazy and haven't done anything I mention above. I'm just NOT a DIY kind a guy. I might JB weld at some point because I don't want dead drivers! And I'll probably recap when my speakers are shot to ****. Or, rather, "someone" else will do that for "me"!
    But if you have the skills, do a search and think about some of the above. It will only help. There, "I" said it!
    cnh
  • boston1450
    edited May 2012
    great advice. i llove these n want them to stay in good condition. i dont over crank them, so i just wanna do what needs to be done. as im not a wiz at electronics. thanx feedback is always a great help
    Randy-Maine
    by David WMG
  • boston1450
    edited May 2012
    ive downsized my gear. still saving for the tube.....soon
    Randy-Maine
    by David WMG
  • drumminman
    drumminman Posts: 3,396
    edited May 2012
    What cnh said.
    There's lots of info here on CP in the Vintage Speakers and DIY Mods sections on how to do all that stuff, recommended parts etc.
    The search engine is a little tricky to use, but it works. After doing some research, post specific questions. Lots of knowledgeable folks here that are willing to help.
    Check my signature - I've done just about all the mods. All they involve is time and money :cheesygrin: and the ability to follow direction.
    F1nut Posts: 51,696
    edited May 2012
    Stop polishing the damn things, not needed.
    Do the TL upgrade and all the other tweaks you'll find documented here.
  • boston1450
    edited May 2012
    very nice. thank you for your information. i write down in my notebook upgrades and mod's. thanx again
    Randy-Maine
    by David WMG
