FXI A6 OR RTI A3 for side surrounds paired along with FXI 30's for rear surround?
Well, more questions, LOL. I am replacing all of my speakers, except for my rear FXI 30 surrounds. The front stage is decided, RTI A9's mains and CSI A6 center. I will keep the FXI 30's for rear surround. Should I get RTI A3's for the side surround or the FXI A6's? The issue is that my sofa is backed into a wall. The rear FXI 30's are mounted way high up near the roof on the back wall. I was using RTI 38's for side surrounds, hence I had decided on the RTI A3's for the side surrounds, but now wonder if I should get the FXI A6's? I had done a test previously and had the FXI 30's on the side with the RTI 38's on the back, but it did not sounds that good. I then replaced the RTI 38's to the side, and the FXI 30's to the rears, and they sounded better suited for the environment. Does this mean that I should get the A3's for the sides and keep the FXI 30's up top, or should I get the FXI A6 for the sides to go with the FXI 30 on the rear?
Post edited by brasil on
I would run the FXI A6's on the sides and sell the FXI30's. If you dont have the proper room or lay out for a 7 channel surround system then just run a 5 channel setup.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
+1 The A6's should do you fine.Placement is everything.Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
Try mounting your FXi30's no more then 2ft above seated ear level. You may have them mounted to high.Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Thanks Guys. You are correct. I will probably get the FXI A6 for the sides, and place the FXI 30's lower from the roof. Since the sofa has to be backed against the wall, due to the size of the room, The side surrounds are on a 36-inch Sanus stand, and the wall is directly behind the sofa, so I will lower the FXI 30's.
