My HK AVR acting like it doesn't like leap day!!!
Dennis Gardner
Dennis Gardner Posts: 4,861
edited February 2012 in Electronics
My trusty HK 7200 is exhibiting strange behavior tonight. My L/R mains output levels took a dive tonight and are -10dB and -15dB below the center speaker level. All my channel settings have always been within 1 dBs of each other since I've set up my HT 5 years ago with no real changes.
I noticed the right channel had dropped around 5 dB a couple weeks ago and made changes to the settings to compensate. I never gave it much thought until tonight when I noticed I had to crank way louder than normal to get any sound from the mains. I did play it pretty hard last night in stereo mode as the wife was out of town for our #3 grandson's birth, but that has never had an ill effect before.
Normal settings would be:
Left main = 0dB
Center = 0dB
Right Main = +1dB
L Rear = 0dB
R Rear = -1dB
Settings tonight per my SPL meter are:
Left main = 0dB
Center = -10dB
Right Main = +5dB
L Rear = -10dB
R Rear = -10dB
It is as though the stereo main settings took a 10dB drop overnight in the preamp section. The results are the same whether I use internal amplification or pre-out to an external amp. The sound is still great, as long as I wildly calibrate the channel settings.
Any thoughts? I have done a hard processor reset with no change.
Post edited by Dennis Gardner on
  • Drenis
    Drenis Posts: 2,871
    Sounds like it needs repair.
  • Dennis Gardner
    Drenis wrote: »
    You may be right. I can't get my mind around why it is crapping out slowly. It still sounds great, just acting wonky.
  • nhhiep
    nhhiep Posts: 877
    this issue is very popular with the HK 7000 and 7200. happened with my 7000 too; center and rears. If you google it, they say to replace a bank of small caps on the top board. I sold mine on CL for $200, then go to Denon AVR and HK Amps. Gonna love that HK sound
  • Dennis Gardner
    I'll pop the top and see if I can see any cap issues. It is funny that the channels that have dropped aren't even using the internal amps, they are preamp out only. I did hook up the receiver amp channels to make certain that I didn't have an amp going out with the same results, so I assume a preamp/processor issue.
  • nhhiep
    nhhiep Posts: 877
    if i remember correctly from 2 yrs ago. it was the DAC board. But google it to make sure ok. you can search for the 7000 too
