Fxi's stand and height, discussion not question :-)
As you' ll know the web is full of advices, from ear height to 6' high. But I did not found anything that relates the height to the room size, which will be instrumental in the sound stage. Its different when you talk of placing a surround at 6' on a 20 feet wide room and different for a 10 feet wide room.
My ear height is 36", so If I go 2 feet above that it is 60", but is this the base of the surround speaker or the height for the driver/tweeter.
I found 2 stands (42" height) that will bring the driver/tweeter height to about (50") that is 1 feet above my ear level. Considering the width of my room is 14 feet, will this be enough for a good surround placement.
Would like to know how many of you are listening surrounds 5.1 at ear height or little above that but below 6 feet
Link to stands that fit the Fxi's base :
http://www.bhphotovideo.com/c/product/144243-REG/Raxxess_ERSS_42_ERSS_42_42_Economy.html
http://www.argosyconsole.com/html_internal/argosyspeakerstands_ClassicStands.html
Polk RTi12
Polk Csi A4
Polk FxiA6
Outlaw LFM-1 EX
Onkyo TX SR806
Adcom GFA 555 MkII
LG 55" 3D 55LW6500
LG Blue ray BD670
Polk Csi A4
Polk FxiA6
Outlaw LFM-1 EX
Onkyo TX SR806
Adcom GFA 555 MkII
LG 55" 3D 55LW6500
LG Blue ray BD670
Post edited by Nerd on
I have a 15' by 12' room. My rears are a pair of FXi300's. They are in a wall mounted bracket approx. 48" high and angled down to the listening position which is roughly 34". They sound great to me and i have no complaints. I have them clamped at front of the bracket and then cable tied to the base of the bracket through the wall mount on the rear of the speaker.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Ideal listening position IMO is having the middle of the speaker at ear level. However, in my case and many others, it just isnt possible. I find that having my speakers where they are and angled as well as manually calibrating the system works very well for me.Shawn
Front: Polk LsiM703
Rear: LSI fx
Today, 04:28 PMshawn474
Ideal listening position IMO is having the middle of the speaker at ear level. However, in my case and many others, it just isnt possible. I find that having my speakers where they are and angled as well as manually calibrating the system works very well for me. .
So I understand from your reply that these 42" stands will work fine too. At the most I will have to angle them towards my seating position of the sound stage goes too high from the surrounds.Polk RTi12
Polk Csi A4
Polk FxiA6
Outlaw LFM-1 EX
Onkyo TX SR806
Adcom GFA 555 MkII
LG 55" 3D 55LW6500
LG Blue ray BD670
