What to replace my Carver c-1 with.
Big Dan R
Im looking for suggestions for a pre amp to replace my Carver c-1 which Ive been using with a Carver M-1.5T amp, powering a pair of Polk SRS 1.2TL's. Ive never been really happy with the C-1. Even before I got the Polks, I hooked it up to my beloved vintage Altecs and know quickly the sound was flat, bland almost clinical. I would like a pre with some warmth and say some definition. Unfortunately budget is about $500.00....
Tks, Dan
Tks, Dan
Post edited by Big Dan R on
It may just be the Carver M1.5T amp you have. You never know. Just swap the amp to a different (relatively newer amp) and see if the sound is still flat and clinical?
The M1.5T is about time to go under recap if it's not done so before. It's probably the amp that needs attention and not the C1 since Day 1.
When I had the C1, I found it's a decent preamp and a lot of people (Carver Fan) will agree.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
People describe the 1.5T as brittle sounding.
The best preamp should not color the sound in any way, shape or form. That's what I always liked about C-1 in particular. I still have one and use it from time to time as my test/reference preamp. If you want warmth, go with the tube preamp.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
