McIntosh advice
ShadesPG
ShadesPG Posts: 89
edited January 2012 in Electronics
i have a shot at a MC2205 listed for $200.
thought i would use it with my pioneer receiver as a pre-amp to run my SDA1c's. if so, i would use the rotel rb980bx amp on my SDA CRS's.
good idea?
bad idea?
good price?
a lot of hassle i dont know about?
thanks in advance
My Living Room
source > Sony DA555ES >
Kenwood GE-74 > Marantz SR4400 > Rotel RB980BX > Polk SDA2.
Pioneer VSX-D909S > Carver TFM-25 > Polk SDA1c.
Pioneer Elite VSX-99 > PSB imageB25.
Marantz 2226 > Polk SDA CRS.
Yamaha RX-V690 > Velodyne Servo F1000.
source > Onkyo TX-DS898 > B&W CC6 (center), B&W DM603, B&W DM601, B&W Rock Solid (rears), B&W AS6.
Bedroom
source > Pioneer Elite VSX-92TXH> ML Quest, B&W DM600 (center), B&W DM601 (rears), Velodyne Servo F1000.
Post edited by ShadesPG on
  • chumlie
    chumlie Posts: 8,658
    edited January 2012
    Killer price. If you don't buy it, pm me so i can.
  • greybeard
    greybeard Posts: 60
    edited January 2012
    Excellent price. You can have it "updated" by a high quality service shop for about $400, if you want to factor that in. That would cover new caps and adjustments if required. - greybeard
  • ShadesPG
    ShadesPG Posts: 89
    edited January 2012
    assuming it works as well as stated in the ad, i dont plan on spend any more money on it after purchase.
    champagne tastes, beer budget
    My Living Room
    Bedroom
  • sucks2beme
    sucks2beme Posts: 5,681
    edited January 2012
    In the case of vintage amps, you can pay them now, or pay them later.
    This is a premium blue meter 200wpc amp. Best to take care of it.
    If not now, then start putting aside money for it. IT WILL hold it's value.
    tonyb Posts: 33,065
    edited January 2012
    ShadesPG wrote: »
    If thats the case, I would hold off on buying vintage gear then. Though the price of admission is cheap enough for you to resell and not lose a nickel should it go south.
  • domflane
    domflane Posts: 653
    edited January 2012
    You could buy it and easily make your money back and some, can't lose either way. Most of us will never own Mac gear, but a lot of us would like to. If you have the opportunity, jump . .
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
    heiney9 Posts: 25,398
    edited January 2012
    ShadesPG wrote: »
    You are also doing a huge disservice by using an AVR as a pre-amp.
  • ShadesPG
    ShadesPG Posts: 89
    edited January 2012
    heiney9 wrote: »
    completely understood...but is that reason enough to pass on it?
    My Living Room
    Bedroom
    edited January 2012
    Probably not if it's in good working condition.
  • vc69
    vc69 Posts: 2,500
    edited January 2012
    Get it. I'm using a refurbed 2205 right now as my primary amp and it sounds fantastic. Not my favorite (I like tubes) but it is no slouch by any standards. $200 is an excellent price, even if it need a once-over, which I would highly recommend. Enjoy!
    a couple of caveats - the binding posts suck. I have some special Cardas cables that are made for the tiny screw down posts. It's something to think about. Also, the stock lamp-cord AC cable is crap. I had mine replaced with a much heavier gauge cord.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • greybeard
    greybeard Posts: 60
    edited January 2012
    By way of comparison, here's a McIntoch MC2205 on Washington DC Craigslist today, asking $950 obo. No affiliation. - greybeard
    http://washingtondc.craigslist.org/nva/ele/2794260474.html
  • ShadesPG
    ShadesPG Posts: 89
    edited January 2012
    thanks guys...as it turned out, the unit was not in the same shape as advertised and would require a bit of money and patience for it to work properly...and thus i decided to pass on it
    thanks for all of the input though
    My Living Room
    Bedroom
