NOOB's 1st set up
edited January 2012 in Speakers
I have a CSi5, two RTi8's, a pair of FXi5's and FXi3's and two PSW505 subs. This will be going in a 13X19 size room. 50% movies, 25% music and 25% gaming. Will it be overkill to run two 505's? Should I run the 3's or the 5's on the side surround position? Should I sell the FXi3's and get another pair of 5's? Thanks for any and all help!
Brad
Yamaha RXA2010 Aventage
Front: RTi8's - CSi5 - 2 PSW505's
Surround: FXi5's
Rear: RTi8's
Height: RTi4's
Post edited by BMP on
Welcome!
    edited December 2011
    That should be a pretty cool setup! Run the 5s for surrounds. 2 subs is not overkill in a room that size. What's powering all of that?
    Oh, and welcome to Club Polk. :smile:
    I will be running at least 7.1 so run the 5's as the side channels or rears? I was looking at the Yamaha RX-A2010 and 1010 receivers. I haven't bought it yet so I am open to suggestions. Thanks for the welcome and suggestions!
    Brad
    EDIT: I see you run a Yamaha Aventage receiver. Can't wait for your reply!
    Surround: FXi5's
    Rear: RTi8's
    Height: RTi4's
    FXi5s on the sides - just my opinion that the side surrounds seem to see more action than the backs. I could be all wet on that, though. 7 speakers is a lot for any AVR to run all on its own, but I think the 2010 could manage, as long as your volume expectations are not unreasonable. The 8s themselves don't present a huge load themselves, and that's a plus. However, the center and surrounds you chose are the larger ones in the series. Having two subs will be a plus, as you can set your crossover around 80Hz and take a bit of the load off your AVR.
    As always, everything will sound better with external amplification. If you think you'll go that route, you might want to consider saving a few bucks and going with the 1010. I like my AVENTAGE... a lot. :smile:
    As the thread states, I'm really new to this. What would your recommendations be for running a 1010 and external amplification? Going that route what channels would you run off of the 1010 and what would you pre out to the external amps? Thanks again!
    Brad
    Surround: FXi5's
    Rear: RTi8's
    Height: RTi4's
    Something like this Adcom, maybe... http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1327965523&/Adcom-GFA---5503---3-channel--
    or this Acurus: http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1328942498&/Acurus-200-x3-power-amplifier-
    There's also Rotel, B&K, NAD, etc...
    Also try looking around on Craigslist, e-Bay, etc...
    If you had larger towers in the front, you could probably get away with amping just the left and right, but with that big center (and that's a good thing), I'd look for at least a 3-channel amp, if you come across a deal on a 5-channel (sometimes easier to find), that would be nice, too.
    edited January 2012
    Thanks for all your suggestions mdaudio! I ended up just buying a RX-A2010. I think it will work well for my first HT set up. BTW I do happen to have another pair of RTi8's for a total of four. Would it work to run the RTi8's for the rear surrounds and the FXi5's on the sides? Or go the other way around, towers on the sides? I know I'm asking a ton of questions, but I have never had a system before and I haven't heard anything other than the "HT in the box" type. I just need to hook this stuff up and get my feet wet! Thanks again!
    Brad
    Surround: FXi5's
    Rear: RTi8's
    Height: RTi4's
Welcome!
Welcome!
