Test Tone CD's
Drenis
Drenis Posts: 2,871
edited November 2011 in 2 Channel Audio
I'm not sure where to post this. Since I have a 2-channel setup, I put it here. Please move accordingly if desired.
Now, I've been doing a lot of reading on test CD's with sine wave tones and different test tones for settings subs and calibrating. Apparently there are many out there. What does the population recommend? I'm looking for something that has tones from 20hz-120hz, but steady tones or sine waves... I want to run REW this weekend but I also am confident that I still have setting issues with my 2.2 setup. I'm becomming frustrated with still trying to get the right sound out of my setup and I've had my setup for 3 months now...
Post edited by Drenis on
  • BlueFox
    BlueFox Posts: 15,251
    Drenis wrote: »
    Really? I haven't found any yet. What I would like is one that generates a signal in the left speaker for a few seconds, and then the exact same signal in the right speaker for a few seconds. My preamp allows me to set the gain of each channel independent of the volume and balance control. A CD like that would let me insure the system is correctly balanced for room acoustics, etc.
  • CoolJazz
    CoolJazz Posts: 572
    Here's a pretty good one. Even includes a set of tracks for the RS meter.
    http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1324922496&/Rives-Audio-Test-CD-2-with-Map
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • Drenis
    Drenis Posts: 2,871
    Wow this is great. I might buy that one off the 'gon. Both have their pros and cons.
  • skrol
    skrol Posts: 3,437
    Look up "The Ultimate Test CD".
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • BlueFox
    skrol wrote: »
    Thanks. This actually looks useful. It is now in my cart.
    http://www.amazon.com/Ultimate-Test-CD/dp/tracks/B0000038NC/ref=dp_tracks_all_1#disc_1
  • leftwinger57
    leftwinger57 Posts: 2,917
    I'm not goofing at all here, how important is what your planning to do and what does it exactly do to your sound..
    tonyb Posts: 33,068
    For 2 channel. I always use my ears as the test cd.
    Drenis, it would be easier for us if you threw up a pic of the room, list the gear, for us to help you. Then maybe explain what it is you don't like about the sound. Test tones are only going to do so much.
  • skrol
    skrol Posts: 3,437
    I have to admit I have not used the test cd for room adjustments, only bench testing. I usually use my ear. Would be interesting to see how well my ear is calibrated.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • George Grand
    George Grand Posts: 12,258
    You have to be kind of careful with those. I smoked a pair of AR-5 tweeters about 25 years ago trying to hear 15,000 cycles. I never did hear the tone but I sure heard both those tweeters departing.
    tonyb Posts: 33,068
    Funny George, you don't strike me as a test tone type of guy. I more so see you using a test tone cd to level out that wobbly table.
  • FTGV
    FTGV Posts: 3,650
    Well it appears he is looking for bass test tones only.I assume since he mentions he has a 2.2 setup indicating dual subs?he likely wants to use the tones in conjunction with an SPL meter to pin point peaks in the bass response due to room modes.With that info he can in turn apply the appropriate amount of EQ/cut to the correct band (assuming he has a parmetric EQ like a BFD)to flatten the response at the listening position.
  • factorz
    factorz Posts: 353
    I have one from Stereophile. It's called Editors choice: sampler and test cd.
  • cristo
    cristo Posts: 231
    I have the Stereophile test cd 2 and test cd 3.
    #2 has channel id, phasing, musical selections, pink noise, 1/3 octave warble tones up the whole spectrum,
    music articulation test tone, distortion and jitter tracks, spot frequency tones, and some others.
    #3 has channel id, phasing, different musical selections, chromatic scales, 1/3 octave warble tones up the whole spectrum,
    Burn in noise, squarewave, multi-tone signals, and others.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • Drenis
    Drenis Posts: 2,871
    FTGV wrote: »
    This.
    The A9's dig deep on their own but I want to match my subs with them whether its setting a xover of 50 or 80hz or running them full range with subs blending in at 50 or 80hz. But I dont know what those tones sound like to hear the room gain. According to my SPL meter, my subs have a 4db (2db with one sub on) advantage over the A9's output. This is with them running full range and subs blending at 80hz. So I was looking for a CD of tones that allows me to test and calibrate my system.
  • donaldfagen
    donaldfagen Posts: 30
  • George Grand
    tonyb wrote: »
    As I said, 25 years ago, when I used to be able to almost hear, I used to love test tone songs. I couldn't hear 15,000 back then, and that's what heated up those tweeters. I figured if I kept on advancing the volume a little bit after each attempt it wouldn't hurt. That's the reason I ended up with my first pair of Polks, the RTA11t. Bought them the day after I blew up the AR-5's at the BX for $290/pair. I guess it was the SL2000 that grabbed me.
    I started listening less and watching tv more right around then, because I used to enjoy watching "in-between" the channels, but then they eventually put some kind of crap on every channel so it was back to listening/reading.
    billbillw Posts: 7,484
    Here is another choice for free. I'm not 100% sure the links are still valid, but if you go through the thread, there might be a newer link.
    http://www.diymobileaudio.com/forum/diyma-sq-forum-technical-advanced/48815-all-6-focal-demo-discs-ready-download.html
    Test tones are on the Tools CD (#2). They have fixed tones, sweeps, white noise, pink noise, in phase, out, etc. The other CDs are very good reference material as well. The music is eclectic, odd, and from extremely varied genres, but the SQ is always top notch.
