glowrdr
leftwinger57
leftwinger57 Posts: 2,917
edited November 2011 in Electronics
thanks forthe head upon the setting page . I followed all your instructions and at first went over the limit then revise the content but now I can't seem to look it in for all to see . I know I'm missing something very simple but again no genius here so if your awake or could respond that would be great. I know I'm with inthe allotted amount of words so thar's not the problem.
  • Glowrdr
    Glowrdr Posts: 1,103
    Was kind of suprised when I was browsing the forums and found my name. lol
    It's there, so I think you're in luck.
    But, just in case - if you go back to your settings (where you edit your signature), and click on "General Settings", about 3/4 of the way down the page you will see "Thread Settings". There you can check the box to add your signature or not. By default, I believe it is on. But that is where you can double check the settings if you wanted.
    After reading, I think that may just be to show other people's signatures, not your own. So your's is turned on, but you may not be choosing to see it.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • leftwinger57
    I kinda like seeing my system progress over the last 2 years. Can't wait for the praverbeal ship to come in and then you'll really see a signature .Thanks again it does make things alot easier....lw
