hd tv bars and boxes
leftwinger57
Hey guys ,I've been dealing w/ this issuse for quite some time and I'm wondering if there is any fix or it's the way it is. Now I fully understand that when something is filmed in HD and transmitted in HD it comes across as a full hd picture .The problem I'm having is when you get these black bars on either side of the screen or even worse it becomes a complete and surrounded box. Now adjusting aspect ratio one might say is a way to go but then I lose graphics on the true hd pictures.So is there any happy medium here or until everything is filmed in hd that's the way it is.For totall transparency my tv is Tosiba au37 maybe 3yrs old and have had no other technical problems w/ the set itself and cablevision is my provider.
leftwinger57 wrote: »Hey guys ,I've been dealing w/ this issuse for quite some time and I'm wondering if there is any fix or it's the way it is. Now I fully understand that when something is filmed in HD and transmitted in HD it comes across as a full hd picture .The problem I'm having is when you get these black bars on either side of the screen or even worse it becomes a complete and surrounded box. Now adjusting aspect ratio one might say is a way to go but then I lose graphics on the true hd pictures.So is there any happy medium here or until everything is filmed in hd that's the way it is.For totall transparency my tv is Tosiba au37 maybe 3yrs old and have had no other technical problems w/ the set itself and cablevision is my provider.
that is called postage stamp when you have a picture surrounded by black bars. Most likely that is the way cablevision is transmitting to you. Does not sound like a TV thing. -
"HD" isn't comprised of just one aspect ratio. I'm assuming your TV is probably 16 X 9 (1:78) since its an HD but a lot of content is 1:85, 2:35, and 2:40 (movies mostly). Here's a better explanation:
http://hometheater.about.com/gi/o.htm?zi=1/XJ&zTi=1&sdn=hometheater&cdn=gadgets&tm=95&f=00&su=p284.13.342.ip_p504.5.336.ip_&tt=2&bt=1&bts=1&st=11&zu=http%3A//www.highdefdigest.com/news/show/High-Def_FAQ/Joshua_Zyber/High-Def_FAQ%3A_Why_Dont_the_Black_Bars_Go_Away/764
or
http://hometheater.about.com/od/televisionbasics/a/aahdtvfaqs6a.htmSony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
thanks for the replys, I did call cablevision just to see if there was a solution and of course there was. My remote was set on fixed for picture format and then when changed to upvert I'm getting fullon views w/o any distortion. I can't beleive I put up w/ this for so long w/o at least talking to someone about it. Another problem solved....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
