Parasound 1205A channel 1 out
sandworms
sandworms Posts: 1,043
edited October 2011 in Electronics
I just scored a used 5 channel and found the first channel wasn't making sound, the other 4 channels work correctly. I noticed that if I put the volume up to -10 or so on my Onkyo 705 that the speaker on that channel will try to make sound, a crackling distorted sound, so when I rotate the level control knob on the back it fades this noise in and out. I was wondering if any of you guys have had this issue and found a fix. I was thinking some Caig deoxit, but read you can't use it on a potentiometer. Any thoughts?
Thanx
Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
Post edited by sandworms on
  • sandworms
    edited October 2011
    just did a search on this and looks like deoxit might have something for the level control, correct?
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
    F1nut Posts: 51,565
    edited October 2011
    Worth a try.
