Help! Loud constant hum when amp is turned on... Parasound 2250
jhkcam
jhkcam Posts: 11
edited October 2011 in Electronics
Hi guys,
I just received the Parasound 2250 amp and there is a very loud constant hum/hiss as soon as the amp is turned on. I have tried multiple sets of audio wires and also switched the ground switch back and forth and there is no change. The speakers do get volume. If I try to listen at a loud volume, I can get the music louder than the hum to where I can't hear it. In other words, the hum doesn't increase as the volume goes louder, it's just a constant loud background noise. When listening at low/regular volumes or when watching television, it's unbearable! Something is definitely not right and I can't figure out what else to check/change. I've tried switching all options on the back of the amp and it doesn't change anything.
Anyone with any ideas on what could be wrong, or what I could be missing, please let me know...
Thanks,
Justin
Video: Samsung UN55C8000
Audio: Onkyo TX-NR809 Receiver, Parasound 2250 2 Channel Amp, Polk RTi12 Fronts, Polk CSi A6 center, Polk RTi A3 surrounds, Infinity Alpha 1200S sub-1 and Rebuilt Infinity BU-150 sub-2
Post edited by jhkcam on
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2011
    This is pretty normal when adding a powerful amp. Get a 3 to 2 prong plug and plug the amp into that & that plug into the wall or power strip and the hum should go away.
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2011
    cfrizz wrote: »
    That might fix it, but I am not sure I would characterize it as "pretty normal when adding a powerful amp". :biggrin:
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2011
    Yeah we need some help here - I never had any humming issues with the amp - and it looks like the amp got to Justin safely. I'm hoping there is some minor setup issue he's facing here.
    Justin - where is the amp plugged in? Power strip or into the wall directly? I don't suppose you could take some pics of the area and the back of the receiver + amp?
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    cfrizz wrote: »
    Holy Crap!! It worked!! Thanks so much!!... why is this?!? Doesn't make much sense why that would be the case, but it absolutely worked!
    -Justin
  • george daniel
    george daniel Posts: 12,096
    edited October 2011
    hummm,, do you by chance have CATV going into the pre/amp? If so,,disconnect it and report back to us please.
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2011
    I always run my cable tv cable through the monster power center to avoid that kind of hum. You should prob give that a shot.
    EDIT: NM looks like you did try it :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2011
    -Justin
    Oh thank god. I was freakin out over here! So is it workin ok now?!
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    PrazVT wrote: »
    Yes sir :D I'll get a new strip as well... Now off to listen. I'll report back later.
    Thanks all!
    -Justin
  • cfrizz
    edited October 2011
    jhkcam wrote: »
    -Justin
    It's usually a ground loop issue with another piece of gear. This is the fastest, cheapest, less time consuming way to make it go away.
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    cfrizz wrote: »
    You go girl!!!!!
  • Beta
    Beta Posts: 267
    edited October 2011
    Sounds like you have an issue with ground loop hum. I had the same problem some time back.
    The 3 to 2 prong plug solved my problem as well. However, I was told by few club members here that this method should only be used as a short term fix. I ended up replacing the 3 to 2 prong plug with an Ebtech Hum X adapter. Works great. No affiliation.
    http://wwwebtechaudio.com/humxdes.html.
  • Beta
    Beta Posts: 267
    edited October 2011
    http://www.ebtechaudio.com/humxdes.html
    Correct link to Ebtech Hum X. Again, no affiliation.
    pitdogg2 Posts: 26,926
    edited October 2011
    tonyb Posts: 33,065
    edited October 2011
    Beta wrote: »
    [/URL].
    Never heard of a case where doing so for an extended period of time did any harm. I have had a cheater plug on my amp going on 5 years with no ill effect.
  • WGDB
    WGDB Posts: 162
    edited October 2011
    pitdogg - your fix sends us to a very weird Karaoke site????
    Pioneer Elite SC-35, Polk RTA (Real Time Array) 12's,
    Polk Monitor 40 surrounds, Polk CSiA4 Center,
    Polk PSW125, Sharp LC-46D62U,
    Panasonic DMP-BD85, Harmony One,
    iMac streaming an Apple TVII, or Squeezebox Touch
    Bedroom Rig~Sony STRDG-920, Polk Monitor 60 fronts, Polk RM6750 Satellites and Sub, Panasonic DMP-BD85
    Rabbit Hole Rig~Yamaha CA1010, Yamaha CT1010, Polk SDA 2A's, Teac A1500 R2R
  • Beta
    Beta Posts: 267
    edited October 2011
    tonyb wrote: »
    That is good to hear. A 3 to 2 adapter can be had for about $2.00 at any hardware store.
    Someone here told me the 3 to 2 adapter should only be used as a short term fix because of grounding issues. Having little knowledge on the subject matter, I swapped out the 3 to 2 adapter with the Hum X.
  • jhkcam
    jhkcam Posts: 11
    edited October 2011
    I decided to put in a new surge protector with the cable in/outs on it for a permanent fix ... I just ran the cable through the strip then out to the box and the hum is still gone. Funny, before this I always wondered why the heck someone would bother running their cable through the surge protector. Now I know :)
  • BlueFox
    edited October 2011
    jhkcam wrote: »
    That makes more sense. I have read here of a lot of people having hum issues due to the cable box. Having an amp with a bit more power should not in itself be a hum creator. I wonder what it is with cable boxes that gives people so much grief.
  • cfrizz
    edited October 2011
    tonyb wrote: »
    Thank you. I've also been using one for several years without any problems. Again it's the quickest least expensive fix that solves the problem.
    edited October 2011
    WGDB wrote: »
    WOW sorry that is very wierd as i just copied and pasted from the site.......NOT the Karaoke site....:redface:
