Can a mid-level AVR drive MMGs?
ROHfan
ROHfan Posts: 1,014
edited October 2011 in Electronics
Simply put. Denon AVR1611 driving MMGs. What can I expect? I plan to upgrade to an AVR with preouts in the future but will this setup work in the meantime?
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
    nooshinjohn Posts: 25,848
    edited October 2011
    So long as you don't push it, you should be fine in the short term, but also do not expect to really be able to enjoy much from the speakers until you upgrade your power. They are really lifeless unless they see plenty of good quality amplification.
  • ROHfan
    ROHfan Posts: 1,014
    edited October 2011
    Thanks, J. Do you think the same would hold true for Martin Logan Electromotions? I've read that they're more mid-level avr friendly and don't necessarily need external amplification to sound good. Supposedly that's how they were designed. I could be wrong.
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    My guess would be a definite yes, the Martin Logan should be easy to drive. The Logan's are 6 Ohm 91dB sensitivity and the MMG's are 4Ohm 86dB sensitivity. You should be able to drive the Logan's with half the power required by the MMG's. Not to say you don't want more (pre-outs + amp) but they will be easier to drive with a receiver.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited October 2011
    Check your manual, most mid level avr's may not be stable under 8ohms and even if they can u won't get the sound the speakers are known for .
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • ROHfan
    ROHfan Posts: 1,014
    edited October 2011
    Thanks for all the replies, guys. I'm humbled. It seems the more I get into this hobby the less I know!
