Receiver for Monitor 70
cascius
cascius Posts: 179
edited September 2011 in Electronics
I guys, I've had my speakers in a storage for 6 months now, and I'm finally moving to a new bigger place and will be unpacking them next week end. I'm super excited and want to upgrade the cheap Onkyo receiver I currently own.
My speakers are the usual Monitor Series: 2x70s, 2x40s, 1xCS2.
When I last checked, people seem to recommend the Pioneers VSX 1020k/1120k. I see that now there are VSX 1121k. The price seems right around what I want to pay ($550ish). Is this still the best choice? I've seen the VSX 52 for the same price and the VSX 53 for a bit more ($650ish). Would those be better options? What about other brands?
My usage is: 75% Movies, 25% music.
Some of the functionality I would like: up-convert everything to HDMI so that I don't need to run more than 1 cable to the TV.
PreAmp outputs for future upgrades.
Airplay would be nice, (not a must).
Also, I'm going to order the PSW 505. That's still the best bang for the buck right?
Thanks in advance,
- Olivier
Main System:
Front: SDA 2ATLs
Center: CS2
Surround: M40s
Sub: PSW505
Receiver: Pioneer VSX-1121k
Amp: Carver AV 705x
TV: Samsung LN52A650
Media Player: Chromecast/Boxee Box
BD Player: Sony BDP-S470
Consoles: Xbox360, Wii U
Post edited by cascius on
  • cascius
    cascius Posts: 179
    Also, I see the VSX 1120k going for about $400 refurbished. Would that be a good deal? What's the difference with the 1121k?
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Amp: Carver AV 705x
  • cascius
    cascius Posts: 179
    Just about to pull the trigger on the 1121k. Anyone has any comments?
    Thanks,
    - Olivier
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Amp: Carver AV 705x
  • B Run
    B Run Posts: 1,888
    Go for it, Pioneer makes great stuff with tons of features. The 70's aren't too difficult to drive, but if you can swing $750 you could get an elite SC-35 which uses Class D ICE amps. It puts out a lot more power and would really wake those 70's up.
  • cascius
    cascius Posts: 179
    Thanks B Run. I did go for it. I figured I could always get a separate amp down the line to drive the 2 front speakers. :)
    Main System:
    Front: SDA 2ATLs
    Center: CS2
    Surround: M40s
    Sub: PSW505
    Amp: Carver AV 705x
  • B Run
    B Run Posts: 1,888
    I had the 1120 for a long time and was happy with it. I added an Adcom amp later and it really woke my speakers up. I ended up ditching the amp and going with the SC and honestly either one is more than enough for what I need. Post pics when you get it all setup!
