Rti 10's
I know this has probably been beat to death a hundred times, however I am about to pull the trigger on some new speaks. I currently have t90e(m60)'s i would really like to get the RTi A7 however there 1000 for a pair or I can pick up the rti 10's for 500. My question is two fold is there a 500 dollar difference between the two in sound quality and how big a step up are the rti 10's from M60's?
Thanks Thomas
PS will also be picking up a Pio SC-35 to run the new speaks.:biggrin:
Thanks Thomas
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Fronts: RTi A7's
Surrounds: Rti A3
Post edited by tommyt21 on
I can't comment on the differences between all the speakers you describe, as I have not heard the A7s or the m60s, but I do own a pair of RTi10s, and absolutely enjoy the Hell out of them. I like them all the way around, but I would also say they were more suited to HT than 2 channel.
Is there a $500 difference? Not sure, really, but if it was my money, I'd put the $500 you'll save towards an external amp and maybe some good quality bi-wire speaker cables (made a huge difference when I did that).So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Yeah I'm pretty sure most of the difference is cosmetic. I'd probably take the 10s over the A7s given that much price difference.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I can tell you I had the 60's and now have the Rti8's, and the 8's are WAY better speakers. I can only imagine the jump the 10's would be, I think the A7's are nice but a lot of the difference with them is cosmetic, maybe slightly smoother highs. I'd take the 10's and put the $500 you saved into something else for your system. I just picked up the SC-35 and I absolutely love it.
