Mixing Tannoy's and Polk??
starkiller
starkiller Posts: 2,723
edited September 2011 in Speakers
Have a Polk passive sub, part of the RM3000 kit, that I want to use with a set of Tannoy I5's. The Polk of course is 8ohm and the Tannoy's are 6ohm. Anyone know if this is or not an ok idea? The Tannoy's sound alot better then the Polk sats do.
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • Joe08867
    Joe08867 Posts: 3,919
    It depends on what you are running it off of. If it is the Odyssey Stratos I thought that was a dual monoblock design? And may not be cool with the idea.
    Besides you will be pushing over 300+ watts probably in the neighborhood of 450 watts at the least at the RM sub. I doubt it will like that very much.
  • starkiller
    This is for the garage system....
