Klipsch KLF-20's
jephdood
Black finish. Excellent condition.
$750 cash local pickup in Auburn, WA. Cannot ship. They're huge.
Pics available to seriously interested parties on request, but would rather people just come out for a look/listen.
If you're looking at this, you probably already know what the KLF's are all about, but here are some specs anyway:
■CROSSOVER FREQUENCY: HF 7,000 Hz, LF 750 Hz
■DIMENSIONS: 40.75" (103.51cm) x 12" (30.48cm) x 16" (40.64cm)
■ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
■ENCLOSURE TYPE: Bass reflex via dual rear-mounted ports
■FINISHES: Light Oak, Medium Oak, Mahogany, Black Satin
■FREQUENCY RESPONSE: 34Hz-20kHz(+-)3dB
■HIGH FREQUENCY HORN: 90(o)x40(o) Exponential Horn
■MID FREQUENCY HORN: 90(o)x60(o) Tractrix(r) Horn
■MIDRANGE: K-52 1.5" (3.81cm) Polymer diaphragm compression driver
■NOMINAL IMPEDANCE: 8 ohms
■POWER HANDLING: 200 watts maximum continuous (800 watts peak)
■SENSITIVITY: 100dB @ 1watt/1meter
■TWEETER: K-79-K 1" (2.54cm) Polymer diaphragm compression driver
■WEIGHT: 86.5 lbs. (39.27kg)
■WOOFER: Two K-1036-K 10" (25.4cm) Poly Carbon Graphite cones
Thanks for looking.
Thanks for looking.
"I did not slap you. I high-fived your face."
Post edited by jephdood on
Great speakers!! Had a set and the matching surrond speakers and 15" sub as well. I hated to sell them but needed to get space back.:frown:
GLWTSMost people just listen to music and watch movies. I EXPERIENCE them.
