'Mini-HDMI's'? (HTPC related)
obieone
obieone Posts: 5,077
edited July 2011 in Electronics
I just dropped $1k upgrading my mobo, cpu, ram, and added a bd-rom, and I'd like to upgrade the GC, but how would the audio/ video work?
Can I use the DVI and mini-hdmi @ the same time?
The reason for this queery, is, I lost the hdmi-out of my SC-05 last year in a lightning strike:frown:
Post edited by obieone on
  • Glowrdr
    Glowrdr Posts: 1,103
    edited July 2011
    You should be able to use them both as long as the hardware supports it (i.e. some will specifically state that it is a video only port even though it's HDMI)
    I havent heard of too many things using mini HDMI though, it's usually a mini-displayport. Not saying they don't exist though.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2011
    Agreed usually graphics card will have HDMI and mini display port. If using HDMI, run cable to the Pioneer.
  • obieone
    edited July 2011
    So, I may or may not get audio out on the mini conn., depending on the GC manufacturer?
    Let me further explain what I'm doing, and what I want to do:
    Right now I've got GC DVI>>>TV, and Mobo 5.1 Optic>>>SC05. I can play BD's but the sound quality isn't that great. I could remove the GC, and just run the mobo hdmi for BD's, but I don't think it's got the horsepower support gaming.
    Therefore, I'd like to find a GC with audio out as well.
    My only other 2 options:
    A: repair the SCO5, (not likely)
    B: replace the SC05($1,100):frown:
  • Glowrdr
    edited July 2011
    Do you need DVI for anything currently? Why not just get a card with dual HDMI outs? Most of the better cards will support audio - but just as a disclaimer, do realize that some do not.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
