More Monitors... or new RTi A's?
piker
piker Posts: 101
edited May 2011 in Speakers
Hello to all of you! This will be my first post as a Polk member. Before I begin, here is my current setup.
Polk Monitor 60 FL & FR
Polk CS1 Center
Polk Monitor 50 RS L & RS R
Polk PSW505 Sub
Onkyo TX-NR808 AVR
I am currently stuck deciding on whether or not I want to make the jump to a couple RTi A7's and CSi A6 that I have had my eye on for a while now. I've read great things about those speakers, but have no idea how much of an improvement in sound quality I would get. I don't want to drop the big money on the RTi A series if it won't be a big improvement. I don't have a way to audition these anywhere near where I live.
Do you think I would be better off upgrading to Monitor 70's and a CS2 for the front sound stage and moving the 60's to the surround position? I know it's a lot cheaper... but I'm very picky about audio quality and I'm willing to spend more if I will actually hear a difference.
The reason I'm so on the fence about it is because I know if I buy the 70's now, I'll likely feel the urge to upgrade everything in a couple years. If I buy RTi A7's, then I would probably be keeping those as my anchor to my HT for years and years to come.
Would using Monitor 60's as surrounds with a RTi A7 front stage sound funny?
Any thoughts and comments are definitely welcome!
AVR: Onkyo TX-NR808
Amp: Emotiva XPA-5 200 watts x 5
Fronts: Polk Monitor 70 Series II
Center: Polk CS2 Series II
Surrounds: Polk Monitor 70 Series II
Sub: HSU VTF-2 MK4
HDTV: 73" Mitsubishi DLP-73740 3D-ready
PS3, 2x XBOX 360, Wii U, Gaming PC.
Post edited by piker on
  • IRLRaceFan
    IRLRaceFan Posts: 172
    edited May 2011
    I sort of went through the same thing a few months ago - I have a set of M70's, but wanted "more"...
    I REALLY like the RTi A9's, on paper, but ended up going with an LSi set up for music.
    Most people here will tell you that the RTi A line is best for Home Theater and LSi for music. I still have yet to listen to a set of RTi A's, but everyone who advised me that the LSi line is a huge jump up from the Monitor line, said the RTi A's were also a jump up and they were NOT wrong about the LSi's!!!!
    You probably can't go wrong with either, but I sure am glad with the choice I made!
    One other thought... Try buying an external amp before new speakers. In most cases, an amp will be a very nice improvement and as you move up the speaker "food chain", you will REALLY benefit from having one (will be a MUST in some cases).
    Hope this somewhat helps you and good luck finding the sound that is right for YOU.
    Shaun
    HT
    Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
    2-Ch
    Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's
  • intangible
    intangible Posts: 262
    edited May 2011
    Incremental upgrades are boring. Jumping up a series or two gives a wow factor that moving within a series generally won't provide. I'd go for the RTis or something better.
    Welcome to Club Polk.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited May 2011
    IRLRaceFan wrote: »
    One other thought... Try buying an external amp before new speakers. In most cases, an amp will be a very nice improvement and as you move up the speaker "food chain".
    Shaun
    This is what i would do in your case. Since you have an avr with preouts, you can get a quality amp to run your setup, which WILL make a difference. And later if u upgrade the speakers, you will already have the power to feed them.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • piker
    piker Posts: 101
    edited May 2011
    Thank you guys for the suggestions. I actually just scored a deal just a half hour ago locally on some used M70's. I got the pair of them for $250, and they are in like-new condition. I'm cashing in on Newegg's sale for the CS2 center ($109) right now to complete the slight upgrade.
    I'll get an amp first and see how I like it with the current setup. It might be enough for me.
    I do about a 60/30/10 split between gaming, home theater, and music listening. Not sure a mix of RTI A7's and Monitor surrounds would sound right while gaming.
    AVR: Onkyo TX-NR808
    Sub: HSU VTF-2 MK4
