Amplifier for Rti12's
breal74
breal74 Posts: 324
edited May 2011 in Electronics
Hello. First time posting, long time polk listener. I have a set of Rti12's running off a Yamaha RX v1800 and am looking to add an amp to power them. There are so many choices for amplifiers out there my head is begining to spin. Does anyone have a similar setup, Yamaha and an amp, or any ideas? Looking to spend around $1000, and yes, I know that each brand has a different sound. Thanks for the help!
Post edited by breal74 on
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    The RXV 1800 is no slouch. Is this just for stereo?
    What are your room dimensions, what is your seating distance? What problems are you currently looking to solve? Used or new amplification?
  • mufsoman
    mufsoman Posts: 636
    edited April 2011
    I'm running a Rotel 1095, 5 channels x 200wpc. Its powering my Rti12's, A6 center and surrounds. Definately crisper sound from the 12's with the amp
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    Ihave an EMOTIVA XPA 5, powering an LSI front sound stage and a pair of monitor 70,s as side surrounds. The amp is rock solid, runs cool, and has a huge amount of power. The LSI,15,s and LSIC are 4ohm speakers. The amp handles 5 speakers with absoulute ease.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • Montoya
    Montoya Posts: 506
    edited April 2011
    If you want a big bang for your buck and want cheap new equipment with warranty get the Emotiva UPA-1 monoblocks.
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2011
    New I would say try the Emotiva XPA 5, but there is so much more in your price range if you consider used. I would also suggest Sunfire, Rotel and Outlaw Audio.
    Outlaw M2200 monoblocks are what I started out with on my RTi12s.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1307745141&/Outlaw-audio-2200-Mono-Amps-1-
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    All of the amps mentioned are terrific, I am very happy with my EMOTIVA XPA5, however its just one of many to choose from.
  • thejck
    thejck Posts: 849
    edited April 2011
    I used a parasound 3500 for a while with the rti12. i liked it alot
  • MADGSF
    MADGSF Posts: 603
    edited April 2011
    Used B&K works nicely with the RTi series and is in your price range.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • breal74
    breal74 Posts: 324
    edited April 2011
    Hello. First off, I sold the Yamaha RX v1800 and bought a Marantz SR6005. Got a great deal and prefered the sound. Now I can't decide between a pair of Outlaw 2200's or a pair of Emotiva UPA-1's. I have read great things about each amp, but have no way of auditioning them. Any ideas or thoughts? I really like the sound of the Marantz if that helps. I just want to "open up" the RTI12s some more. Thanks!
    F1nut Posts: 51,774
    edited April 2011
    You like the Marantz AVR you just bought, so get a Marantz amp to go with it. Marantz has a warmer sound, which as you have discovered, mates better with your speakers. The two amps you mentioned would not be a good match with your speakers unless you like ear bleeds.
    The B&K is another good suggestion.
  • jinjuku
    edited April 2011
    breal74 wrote: »
    What city do you live in/near. Craigslist is always a good place to look.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2011
    I have used several different amps with my RTi-12s. Of all the ones I used I liked the B&K ST202+ the best. The B&Ks warm sound is a good compliment to the RTis slightly bright sound. It helps smooth them out. One thing I can truly say about the RTi-12s is the more clean power you give them, the better they are. I tried several amps on them in the 200 to 250 wpc range and they all sounded good. The RTis did not truly come alive however till I biamped them using two 200 wpc amps. The bass was simply unreal with this setup. I didn't even need a sub while running this. I don't think the difference was due to the biamping, but was due to the increased wattage. My advice would be to try to get the highest wattage you can from an amp made from a good reputable company. Two amps biamped would also be a good choice, but I'm trying not to complicate things for you (even though it's not that hard to passive biamp using two amps).
  • breal74
    breal74 Posts: 324
    edited April 2011
    How is the sound of rotel and carver amps? I have a feeling they are on the brighter side compaired to the sound of Marantz.
  • Emlyn
    Emlyn Posts: 4,708
    edited April 2011
    My RTi12's never sounded better loud than when they were powered by a Rotel RB-1090. A used one in good condition should be in the $1K range. It's a big heavy amp though, so your rack would need lots of room. Fortunately, the amp runs pretty cool and has casters on the rear for sliding into a rack.
  • breal74
    breal74 Posts: 324
    edited April 2011
    Thanks for all the feedback! This is a great site!
  • deseroner
    deseroner Posts: 155
    edited May 2011
    anyone used a 450wpc amp on rti12 , wonder how they will sound,waiting on my carver 1.5 pm
    receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
    mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
    center : snell xa1900 4ohm 250w,nordost flatline
    subs-klipsch-ksw10/athena asp-4100
    rear-OWM3 - 8ohm 100w
    surrounds-klipsch rs-7 150w
    amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
    power.c-bpt cpc/ps.soloist ci.
  • Montoya
    Montoya Posts: 506
    edited May 2011
    I had a carver 1.5 and rti-12 it's a good amp it has it's own sound some love it some hate it. It will drive them fairly well but I liked the Rotel 1090 so much better it's one of the amps I regret getting rid of it drove them effortlessly. The bass response in two channel was amazing at moderate levels you felt the force of the bass through your chest. The carver was good but the bass response was lacking but it had a fuzzy tube like sound which was nice.
