Bought Carver's new tube amps on ebay, have SRS 3.1TL, now what?
Odysseous
Odysseous Posts: 25
edited April 2011 in Vintage Speakers
Hi guys,
I just bought Carver's BLACK BEAUTY tube amps on ebay and I obviously want to use it with my Polk Audio SRS 3.1TLs. I have the inter connect cable, but just the regular one that you can use with common ground amplifiers. Two questions: I do need the other more complex interconnect cable, right? And if so, where can I get/make one?
Thanks!!
Carver hand built 305 watts BLACK BEAUTY vacuum tube amps
Carver C-19 tube pre amp
Carver SD/A 490t tube CD player
Carver TFM-45 amps (3 of them)
Carver TX-11b radio tuner
Carver TD-1700 cassette deck
Polk Audio SRS 3.1tl
KEF Reference Model One
Post edited by Odysseous on
  • engtaz
    engtaz Posts: 7,669
    edited April 2011
    Talk to some that own them or Bob to see how to make the mono amps common ground. Sometimes you can put chassis grounds together but ask Bob Carver to make sure.
    Congrats
    engtaz
  • brgman
    brgman Posts: 2,859
    edited April 2011
    Ben can fix you up with a cable.
    Or you can just send the beauty's to me and the world will be right again.:rolleyes:
    I’M OFFENDED!!!!
  • chandler9a
    chandler9a Posts: 878
    edited April 2011
    I can't answer your question but we would all love to see pics of the setup when you get it in place as well as hearing your impressions of the system.
    Have fun!
    F1nut Posts: 51,798
    edited April 2011
    You need to buy the original Polk AI-1, make one yourself or have one made for you. You will not be able to tie the chassis grounds together.
    Link: http://www.polkaudio.com/forums/showthread.php?t=74472
  • FTGV
    FTGV Posts: 3,650
    edited April 2011
    engtaz wrote: »
    Yep ask the man himself.
    nooshinjohn Posts: 25,932
    edited April 2011
    Last I checked with Bob, he said strapping the negative outputs together was ok to do, but I will be making an AI-1 just the same.
