Adom 7500 Bridgable? Rti10's
Cmiller
Cmiller Posts: 108
edited March 2011 in Electronics
What is this bridgeable option? The adcom 7500 is 150W 8 ohm or 220W 4Ohm"mono blocks"..my Front speakers are Rti10 that run @ 4ohms..im currently using the 7500 for my front 3 speakers and using th SC-25 for rears.Im just wondering if i could use the 2 channels on the 7500,that im not using,to give the Rti's some more juice..Possible?...thanks guys
Samsung PN50B550 Plasma
Pioneer Elite SC-25
Pioneer Elite BDP-23FD
Adcom 7500 Amp-Panamax 4300 Conditioner
Polk RTi10's Fronts
Polk Csi A6 Center-Polk M60s rear Surrounds
Klipsch Synergy Sub-10 X2
Klipsch Synergy S-10 Premium back surround
Post edited by Cmiller on
    F1nut Posts: 51,786
    edited March 2011
    The RTi10's are 8 ohm loads, not 4. Your Adcom is a 5 channel amp, I don't think it is bridgeable.
    tonyb Posts: 33,072
    edited March 2011
    Your already giving them plenty of juice. If you want,throw those extra 2 channels to the surrounds.
  • Cmiller
    Cmiller Posts: 108
    edited March 2011
    I know it says 8 Ohms on Polks site,but have you read this?
    http://archive2.avsforum.com/avs-vb/archive/index.php/t-577805.html
    But even if the Rti's 10's are 8ohms,the Adcom 7500 says its bridgable
    Pioneer Elite SC-25
    Polk RTi10's Fronts
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    Airplay355 wrote: »
    Yep 8 ohms
    Correct. Not bridgeable
    tonyb wrote: »
    Plenty of power.
    I had that same amp. Don't compare receiver watts to an amps. Are you getting the distorion lights to flicker?
    Ben
  • Cmiller
    Cmiller Posts: 108
    edited March 2011
    ben62670 wrote: »
    Yep 8 ohms
    Plenty of power.
    Nope on the flicker lights..Ok i'll just leave it as it is,becuse the sound is Incredible ..Watched the lastest "Robin Hood" last night,and the horse's running and arrows flying around was crazy good..lol
    Pioneer Elite SC-25
    Polk RTi10's Fronts
  • ben62670
    edited March 2011
    If the distortion lights don't flicker you are not over driving it. Even if they flicker just a little you are OK.
    Enjoy.
    Ben
    Ben
    F1nut Posts: 51,786
    edited March 2011
    Cmiller wrote: »
    You should read that thread again. As pointed out by one member, sticking a VOM into the binding posts will not give you the nominal impedance.
  • Cmiller
    Cmiller Posts: 108
    edited March 2011
    yea i saw that,but it also says,why would that matter..anyways..im just going to leave everything as is..the system pounds..:)
    Pioneer Elite SC-25
    Polk RTi10's Fronts
