Kenwood BASIC M2 & RTA 11T's
STORMINORMAN
STORMINORMAN Posts: 9
edited February 2011 in Electronics
Just picked this amp up: don't know if this is the right forum but what are the opinions as to using this (have a "2nd ZONE" pre-amp out on my ROTEL Pre/Processor) to power a propective pair of RTA 11T's? Thinking my records might sound good through the Tandberg's phono section as well, using it as a pre-amp.
1st post: please be kind!
Cheers!
I:ROTELpre/proADCOM5Ch,AtTechSub,Monitor7&5Jr's,B&WCenter,SamsungBRay,YamDVD(24bit for CD's) II:YamCX-1000,MX-1000,TX-1000,KX-W602,EQ-70&CDC-815 driving NS-1000M, +MitsubishiAmp driving ATRIUM4 III:YamRX-V596+Boston Ac Micro90C+(4X)Micro90SamsungBRay,VelodyneSub &42"LG LCD
IV:another RX-V596 JBL Towers, JBL3way BS & Sub, PhillipsDVD, Pana42"Plasma V:Tandberg Receiver, NEC CD TechnicsDDCas&Turntable&,Sigma,MitsuVCR VI:BOSELifestyle 12 via hp desktop VII:Toshiba 24"&SD-H400 DVD/TiVo
Post edited by STORMINORMAN on
  • skrol
    skrol Posts: 3,452
    Welcome to the club. I didn't quite catch what amp you will be using. My RTA11TL's are fairly easy to drive. I assume that the RTA11T is too.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • STORMINORMAN
    Thanks!
    The new amp is the Kenwood BASIC M2
  • Boonaroo
    Boonaroo Posts: 57
    The Kenwood Basic M2 should be fine for a set of RTA-11's.
    Using it through Zone 2 should work just fine.
  • gwg_97
    gwg_97 Posts: 332
    The Basic M2 is an excellent amp. I've used one with my monitor 10s for about 25 years. Great bang for the buck!
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
