Got two AVR'S can I use then in conjuction with each other
rogerd
So just wondering if there is some way I can use my old HK 510 (80 watts) that has preamps with my HK 2600 (65 watts) I know I should have picked up the 3500 but you know the old saying hind sight is 50 50
Or run then separate use the 510 to drive my PS3 via the Fibre Optic cable for listening to BR music videos and CDS and just run more cable to the speakers?
My speakers tSI 500, tSI 300, CS20, Kef sub
Post edited by rogerd on
Just use one, using two will just make things complicated and probably not sound very good.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Ya your probably right, Its just that the HK 510 is sitting in my garage doing nothing thought I could use it somehow.
Cheers for now. R -
Use it for a garage system. Just because you CAN do/use something, doesn't mean you should.Main Surround -
Maybe I will, Gives me an excuse to buy some used Polks I seen on EBay. -
So just wondering if there is some way I can use my old HK 510 (80 watts) that has preamps with my HK 2600 (65 watts) I know I should have picked up the 3500 but you know the old saying hind sight is 50 50 .
My speakers tSI 500, tSI 300, CS20, Kef subDARE TO SOAR:
