Ripping CD's to Flac
ben62670
ben62670 Posts: 15,969
edited January 2011 in 2 Channel Audio
What is the best tool for the job that transfers album info to the rips?
Ben
Ben
Post edited by ben62670 on
  • punk-roc
    punk-roc Posts: 1,150
    edited January 2011
    I use Exact Audio Copy (EAC).
    steveinaz started a thread similar to this that probably has some answers too..
    http://www.polkaudio.com/forums/showthread.php?t=91901&highlight=CD*+ripping
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • ben62670
    edited January 2011
    Thanks. I tried searching, but...
    Ben
  • punk-roc
    edited January 2011
    No worries, its easier to find when you know its there =) I remembered his thread
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited January 2011
    iTunes, under options select apple lossless that is all I use. not to meantion the library is well organized to find what I am looking for.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • olilugo
    olilugo Posts: 405
    edited January 2011
    Ben to answer your question directly I use a windows app called winamp to rip cd's to .flac format
    http://www.winamp.com/
    It is free
    I have also tried itunes to rip the CD's to the .m4a format.
    Both of these formats are lossless and I have to say I can not hear the diffrerence between the two file formats.
    One thing I have found as far as functionality is when you have a cd that one song follows the other like in a concert CD. winamp will rip all tracks individually but if you happen to shuffle then the end of the sond end very hard and its not the same as listening to the CD.
    Itunes has a way to join several tracks or all track of a CD which means the CD entire track will play and the hard cut between tracks will be just like listening to the original CD.
    I hope this helps.
    I would love to hear other people experience between these two formats as they both use more space and I am tempted to drop the flac format and just go with .m4a format.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited January 2011
    +1 to EAC. I've been using it for years to rip to multiple formats. I wish I had settled on one format years ago. Went with mp3 years ago, due to file size, since storage and transfer were both issues back then... not really issues anymore. FLAC is a great solution, IMO.
    I know I'll get bashed for this, but I still find that mp3s encoded at a high enough bitrate (320?) sound about the same to me as a CD. I know, either my ears or my gear's not good enough. :smile:
  • ben62670
    edited January 2011
    EAC keeps crashing and says there is no CD in the drive:confused:
    Ben
  • mdaudioguy
    edited January 2011
    olilugo wrote: »
    It is free
    I don't think m4a is a lossless format, IIRC.
  • mdaudioguy
    edited January 2011
    ben62670 wrote: »
    Did you run the configuration wizard, where it checks the features and capabilities of your drive(s)? At what point is it crashing?
  • ben62670
    edited January 2011
    I open it and shortly after it says that it is not responding. I can't even get to any of the tools. I am running Win7 64bit.
    Ben
  • mdaudioguy
    edited January 2011
    I run it in 32-bit W7. Not sure if that's the problem, though. I thought W7 64-bit was supposed to handle it either way.
  • mdaudioguy
    edited January 2011
    You could always try uninstalling and reinstalling using an older (XP?) compatibility mode.
  • intangible
    intangible Posts: 262
    edited January 2011
    I usually just use Foobar2000, which runs fine on Windows 7. EAC does a more thorough job error checking (I think, it's been a while since I last used it), but it takes longer, and I always figured if I heard issues with a file I could just rip it again.
  • Earthy
    Earthy Posts: 488
    edited January 2011
    I found this thread http://www.polkaudio.com/forums/showthread.php?t=91901 and dl'd EAC configured with settings from here.. http://carltonbale.com/cd-audio-extraction.
    I'm using W7 64bit on an I5 with no problems (so far).
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • bikerboy
    bikerboy Posts: 1,230
    edited January 2011
    Hi Ben,
    I found Media Monkey works well for me. I rip to flak and covert to mp3 for use on my phone. I use win 7 32 bit. When you use random you can have fade out/ in if you want.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    edited January 2011
    I have had no issues converting to WMA. It tags properly with track numbers, names, and the artwork. I have not found a single FLAC converter that works right yet:mad:!!!
    Ben
  • ben62670
    edited January 2011
    olilugo wrote: »
    It is free
    I hope this helps.
    It does what it should right out of the box!
    Ben
    Ben
  • olilugo
    olilugo Posts: 405
    edited January 2011
    Glad to hear.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    heiney9 Posts: 25,421
    edited January 2011
    dB Poweramp
    http://www.dbpoweramp.com/
    or
    Media Monkey
    http://www.mediamonkey.com/
    Media Monkey is the best program I've ever used.
  • punk-roc
    edited January 2011
    I use dB poweramp with great success for converting my. FLAC files to mp3 for when I need them in my car. Easy and fast..
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
    edited January 2011
    dB Poweramp converts cd's to FLAC and is bit perfect. Best program going for this, even better than EAC as it's more flexible.
    dB Poweramp and Media Monkey are the best computer audio programs going. The capabilities and flexibility of MM is awesome both as a player and music database manager. It is an amazing piece of software. Best capability is I can upload a document file from MM of all my music into my iPod Touch so when I'm in the music store I can make sure I don't buy duplicate titles.
    Being able to sync MM with the iPod means I don't have to use iTunes to load my own music on the iPod.
  • nclh7
    nclh7 Posts: 38
    edited January 2011
    I dumped any type of lossy compression about 2 years ago(mp3, aac) and went lossless apple.
    Now with the size of my hard drives, there is no need to do any sort of compression and I just take it as a 1411 wave file. Everything will play a wave file so no worries about future obsolescence.
  • PrazVT
    PrazVT Posts: 1,607
    edited January 2011
    +1 for db poweramp for the reasons H9 pointed out. I use it for FLAC (SB Touch/Classic) and for Apple Lossless (iPod for the Car). Great CD ripper.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • ESavinon
    ESavinon Posts: 3,067
    edited January 2011
    If you have an unused old computer, I recommend Vortexbox.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
