3 setup's opnion request.
Hello guys.
Firts time in here and got more info than ever after several phone calls to some stores.
Well, being direct to the point... Im betwen these 3 setups. Any opinions are welcome.
Just letting U know that Im focusing in powerfull sound to listen eletronic music and stuff like that.... movies is very secondary.
System #1:
TSi 500s
CS 20
TSi 100
PSW 505
Onkyo NR808
System #2:
RTi A5
CSi A4
RTi A1 (not happy in spending this)
PSW 505 (any better quality sub????)
Onkyo NR808
System #3:
RTi A7
CSi A6
RTi A3 (too much for not a movie fanatic)
PSW 505 (same question here)
EMOTIVA XP3
Onkyo NR708
After this Im sure I will be done with this.
thanks
Gera
System #1:
TSi 500s
CS 20
TSi 100
PSW 505
Onkyo NR808
System #2:
RTi A5
CSi A4
Onkyo NR808
System #3:
RTi A7
CSi A6
EMOTIVA XP3
Onkyo NR708
thanks
Gera
Post edited by geraban19 on
Well...what's your budget?
It's not exactly apples to apples when comparing the 3, though I'd most likely steer torwards System #3 and opt for a different amplifier than an Emotiva. That and I'd probably grab a Pioneer AVR instead (personal choice).
So, again what's your budget?
System #1 would be the most economical and won't require an external amp though I'd suggest grabbing Monitor series speakers when on sale from Newegg.
That or I'd suggest purchasing some Polk refurb's from their Ebay store. Buyers swear the refurbs are as good as NEW, and they're still covered by factory warranty.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Oh and another thing, if you're going with the RTiA's I'd suggest a bigger/badder subwoofer to keep up.
Not saying the PSW505 is a slouch, but you'll want something that digs deep. Check out SVS, HSU Research and Epik subwoofers for your subwoofer needs
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Welcome, since you only want to do this once and then enjoy it for years, go for option 3This setup will give you pleasure for years to come, you speakers will be operating to their full potential thanks to the amp. If you want to, switch out the RTi a3, for the FXi a4 speakers. And also think about upgrading your sub to a DSW 400 or 500.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
For primarily music.....none of the above. You should consider an LSI system or SDA's.
A budget and room size would help.
If I had to choose, and using it for music I'd pick #2. I've heard both the A5's and A7's and feel the A5's are more musical, as Frizz suggested look at the DSW 500 for a sub. -
You've pretty much answered your own question. If you don't want to spend the money for the surrounds, don't do it. I think setup 3 is the best bet however. Also, have you tried multi channel surround for music?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Welcome to Club Polk geraban19Well...what's your budget?
... That and I'd probably grab a Pioneer AVR instead (personal choice).
-Freddy
I agree with the above from Freddy. You seem to be budget concerned which is fine (can you elaborate on a specifc amount?). Freddy has suggested the Monitor series when on sale would definitely be your best bang for the buck. The PSW505 would definitely be a good match with them. I too agree with Pioneer over any Onkyo receiver however, this is a personal opinion/preference and somewhat subjective.
You mention you do not care much for a killer HT set-up as your main goal/desire is a good set-up for music so why an AVR and center? Why not focusing on a good 2 channels set-up? IE: Monitor 70s and possibly a Harmon Kardon such as the HK3490? You would save some money, you focus your budget on better 2 channel gear and don't forget you still can watch the odd movies with quite decent results as with proper placement of your speakers you would create a phantom center for the HT experience...DARE TO SOAR:
