Power Amplifier addon
Swede_Deep
Swede_Deep Posts: 23
edited November 2010 in Electronics
Fronts: Monitor 70's
Center: CS2
Rears: Monitor 40's
Sub: PSW505
Receiver: Onkyo TX-SR707
Panasonic DMP-BD65
Panasonic TC-P58S1
Would a MOTIVA XPA-5 FIVE be a good choice for more sound out of this small system? Or any other better suited recommendations here?
Post edited by Swede_Deep on
    EndersShadow Posts: 17,687
    Swede_Deep wrote: »
    Center: CS2
    Rears: Monitor 40's
    Sub: PSW505
    Panasonic DMP-BD65
    Panasonic TC-P58S1
    Personally recommend going with a 3 channel amp for your front three and leaving your surrounds to the receiver as they normally dont need/require much wattage. 70% of your sound effects come from your front left/right speaker and 90% of your dialog comes from your center. Your surrounds normally just supply ambient sound and other placement sounds that dont require that much wattage to produce. Suggest the Emotiva XPA-3 or UPA-3. Either one would work great for those speakers. Personally suggest the XPA since it has more power if you ever look into 4 ohm speakers (like the LSi's)
  • Swede_Deep
    Well that is even a couple of hundred cheaper, and might be all that I need for now. Still brand new about all this. Thanks for all the detail in your answer!
    No problem. Always glad to help a fellow Polkie save a few bucks. If you have any other questions feel free to ask. Welcome to CP!
  • cfrizz
    cfrizz Posts: 13,415
    All speakers benefit from more power INCLUDING the surrouds. They really came to life when I hooked them up to my 5 channel amp. What's more, if he listens to any sacd's or dvd-a's quite a bit of information comes from the back channels.
    Do it once and do it right and you won't have to think about this particular upgrade for years.
  • Swede_Deep
    Thanks for the input.
    Wouldn't the upa-5 be a good choice? I just though that the xpa-3 would be to much for the cs2?
  • cfrizz
    Swede_Deep wrote: »
    There is no such thing as too much power. I have all of my speakers powered by a 5 channel Sunfire 405wpc amp and they sound great.
    Having this much power you will know that your speakers will be getting all the power that they need to run to their full potential. Which is the whole point of amping them.
    The Xpa-5 will power any speakers you have now and in the future, especially if you someday decide to step up to harder to drive speakers like the LSI series which definately needs at least 200wpc to sound their best.
    I'm not one to constantly switch out gear and the try it and return it system will still cost money with return postage & time spent. If you got the Xpa-3 and liked it, then you would start wondering how good the rears will sound (been there done that) and that would be more money spent. Just get an Xpa-5 and be done with it.
    I know that it is more money, but as I said, it will last you for years to come through all other upgrades to your system.
  • Swede_Deep
    I will set my cash away for the xpa-5. I think that I will be happy with that. It will be the last upgrade that this little system will receive.
    Thanks for all the Input!
