PrePro's
LeftCoast
Thinking of what pieces I will be getting next, I like the Sunfire Cinema Grand Signature 7x400 amp.
Now what to hook up to it?
Is there a pre pro out there comparable to the Denon 4810ci? I am thinking about the cool video processing, playing around with different speaker set ups.
Or should I get that receiver...now available for under two grand? That way if I do additional speakers, I can use the Sunfire 7 channel amp and use amps from the receiver to power additional speakers.
Some guidance for a confused newbie, if you don't mind.
Buy the Denon, you won't be disappointed.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Serendipity wrote: »Buy the Denon, you won't be disappointed.
Should I use it the way I described? (In case I go with a 9 speaker set up)
