BDP-51FD: 'Function not available' for multi-ch. out?
obieone
obieone Posts: 5,077
edited October 2010 in Electronics
Back when that lightning bolt took out my tv, I fried the hdmi out on my rcvr. Soooo, I figured I would use the components out, and the multi-ch. out as well, for BRD's. No luck:mad: It's stuck in 2 ch., and 'function not available' message:mad:
I could use the optic out, but it doesn't sound as good as hdmi, and that wont do the codec for BRD's(or so I've been told)
And yes, it has the most recent version-1.37.
TIA for any help:(
Post edited by obieone on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    Probably not what you're wanting to do but why not use the multichannel analog outs? You'll be able to receie the new codecs since they're not output via optical/coaxial.
    Got one myself that's up for sale ;)
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • obieone
    edited October 2010
    Thanks, but I just figured it out. I did NOT have 7.1 selected on the disc, and there was a setting not right in the audio menu.
    This format requires an advanced degree in engineering!:o
  • obieone
    edited October 2010
    kawizx9r wrote: »
    That's what I was concerned with. I could NOT get the analog outs to work, but I got it figured out eventually
