Polk Cobra cables as IC's?
organ
organ Posts: 4,969
edited October 2010 in 2 Channel Audio
I still have my Polk Cobra speaker cables. They need to be re-terminated and I'm thinking about cutting about 1/2m to try out as an interconnect cable. I haven't heard that many speaker cables, but the Cobra is my favorite.
I'm scared I may damage something. Afterall, this is the cable that's been known to kill some amplifiers.
For those who have experimented with this cable, what do you think?
  • mmadden28
    mmadden28 Posts: 4,283
    edited September 2010
    Have any pics of them?
    What was it about them that 'killed' amps?
    ____________________
    Pool: Atrium 60's/45's
  • nadams
    nadams Posts: 5,877
    I believe they were highly capacitive? Also, they had a sensitive ceramic insulation that could be more easily broken than others, and made for shorting out an amp. There's other threads on here that can lend some insight.
    Ludicrous gibs!
  • nadams
    nadams Posts: 5,877
    Here's an old old post on them (including the legendary nascarmann (RIP)) - http://www.polkaudio.com/forums/archive/index.php/t-4171.html
    Ludicrous gibs!
  • Face
    Face Posts: 14,340
    I doubt it would sound very good as an I/C.
  • megasat16
    megasat16 Posts: 3,521
    If what people have said is true about the Cobra being capacitive, you don't want to use it as an IC if you prefer wires without color. Normally, very thick cables and several parallel wire design such as Cobra could be high capacitance in nature and it's best to avoid them as I/C.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • madmax
    madmax Posts: 12,434
    I'd do it in a heartbeat to see what it sounds like.
    madmax
    Vinyl, the final frontier...
    heiney9 Posts: 25,721
    Don't ruin a good pair of rare Polk Cobra cables for that. Most decent I/C's have a shield and a drain. They are not simply speaker cabling with an RCA on the end.
    It would be a waste and not sound very good IMO.
  • organ
    organ Posts: 4,969
    Thanks for the input guys.
    Megasat,
    I forgot to post this, but I'm not running multiple sets in parallel, just a single run. People run multiple sets for a bigger ga. I think a single run is only 16 or 18ga. Mine goes to very sensitive speakers and not a long run, so one set is good enough.
    What do you think about a single run?
    Madmax,
    I swear man, I think I got these from you. Do you remember? I think I got them from you or HBomb.
    Heiney,
    Oh no, I would never ruin them. The pair I have are a little longer than what I need. So I would only be cutting about 3ft from about each 17-18ft run.
    Maybe I'll PM Ken S. I'll let you know guys know what he says.
    I'm afraid something might go poof if I decide to do it.
  • kawizx9r
    kawizx9r Posts: 5,150
    organ wrote: »
    Thought people ran several pairs because of the high-capacitance. They wanted to reduce it overall by running multiple wires.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • organ
    organ Posts: 4,969
    Interesting. Last I heard it was to increase wire size. Ok, I'll PM Ken now.
  • megasat16
    I think the Cobra cables is composed of multiple wires run in parallel inside one big thick cable? I have never seen it so if you have pic of it, it would be real helpful for informational purposes.
    After you cut the Cobra to the length you want and you found multi-wires inside the thick speaker wire, you may as well use one wire (if there is an insulation / jacket on each wire) for the I/C and it should work fine. Just don't use the whole thick speaker wire as an I/C.
    I also agree with H9 about normal wires using as I/C without proper shielding is not a good idea. You can buy shielding from the parts express, I think.
    From digging the old threads around, I found this.
    POLK (COBRA) SPEAKER CABLE (IN PARALLEL ONLY!)- This speaker wire (8 cables in parallel) has proven to be superior to every other cable that I have compared with it, at all prices points, for over 25 years now. It was even far superior to the $15,000, top-of-the-line Kimber at the Las Vegas CES show a few years ago.
    http://www.polkaudio.com/forums/showthread.php?t=38160&highlight=cobra+speaker
    http://www.high-endaudio.com/RC-SpkrCab.html
  • madmax
    organ wrote: »
    Madmax,
    Yeah, I think those are my old ones.
  • organ
    organ Posts: 4,969
    Megasat,
    Sorry, my bro took the camera. I'll post a pic when I get it from him. But the wire is pretty much exactly like you described. I have the flat version. They made a round and flat version.
    Thanks a lot for the links. Very interesting reading. I will look for some insulation. Thanks again.
    OK, I'm going to give this a shot. Here's my short conversation with Ken:
    "Hi Ken,
    I have a long run of Polk Cobra cables. If I cut a 3ft pair, can I use them as interconnect cables? I'm worried about the capacitive nature of the cable. It would be going between the tube output of my cd player and my tube integrated amp.
    Thanks"
    Ken's reply:
    "Hello!
    The output impedance of the CD player should be low enough that the relatively small capacitance of the cable shouldn't matter. Give it a try.
    Ken"
    Well, the guy who will be working on my Cobras is the same guy who built my cd player, so I'll have him check the impedance and take some measurements to make sure it's ok.
    I will probably have this done in about a month or so. I'll let you guys know how it goes.
  • megasat16
    Yeah, give it a shot. As long as you keep I/C to one wire (if it got it's own insulation jacket) for each channel, I think capacitance problem should not be an issue. 3' is a short length but I still think crosstalk between R and L channels and there is a high chance of noise and interference due to no copper foil shielding. But I don't see why not give it a try? :)
  • madmax
    edited October 2010
    Don't forget that each strand is coated with insulation.
