Help Mounting Monitor 40's Front Height
Any suggestions? I was going to just settle for 30's but I really want to use the 40's. I've been browsing and liked the BT-77 brackets but I think the monitor 40's are slightly to big for it. I want to mount them above my tv since I just bought the Pioneer VSX-1120-K and use them as front height speakers.
Also, I'm assuming if they are mountable I will have to drill holes in the back of the speakers. What are the side effects of that if any? Thanks.
Post edited by AlienKill on
I checked out the 40's specs and the BT77's will work fine.
Enjoy:)Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player -
ive seen people using BT77 with monitor 40 for surrounds in this forum. u should be fine.Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU -
I used the AM40 Pinpoint Mounts for my Monitor 40's. And instead of drilling the holes to attach the speaker to the bracket I used Velcro along the bottom. Has been working great so far and I dont have holes in my speakers
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Nice idea EnderHT and Music Rig
Receiver- NAD T765 HD
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Surrounds side- Polk Audio Monitor 60
Sub- Polk Audio PSW505
Windows 7 Media Center
T.V.- 40" Sony Bravia LCD 1080P
Blu-Ray- 80 GB PS3 -
Alright sounds good. But EndersShadow just to follow up... velcro? 40's are huge! Just wanted to double check on that. How you went about doing it all I guess.
Also thanks everyone for the tips. I appreicate it
Yup, I used big patches of velcro that ran across the front of the bracket and the back (since it dips in the middle that would have been pointless). It works great! You still have to use the clamps, but I found that the back of the speaker had a tendency to pull up and away from the mount (see the guide on this forum somewhere with pics to see what I am talking about). Adding that back section of velcro kept it flush w/ the bracket and the clamps do the rest."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I think there are different strenghts of velco (if strengths is the right word...) I seem to remember that there are some kinds of velcro that are really strong for things that are meant to pretty much stay put....not detach and re attach over and over again.
Do you buy that velcro at hardware stores like Home Depot or Lowes?HT and Music Rig
Blu-Ray- 80 GB PS3
