optical audio out... what happened to it?
Micah Cohen
Micah Cohen Posts: 2,022
edited August 2010 in Electronics
I won't go into my whole bluray vs SD-DVD thing here. But I've just noticed that there's not one SD-DVD player on the shelves that has the OPTICAL AUDIO OUT jack no more. (Even non-HDMI players don't have this jack no more.)
Why is this? Where did this output go?
MC
ultramicah@yahoo.com
"There's nothing funny about a clown in the moonlight." - Lon Chaney
Post edited by Micah Cohen on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2010
    Face it, you're getting old. I said the same thing when transistors came out. Where's the tubes?
  • hoosier21
    hoosier21 Posts: 4,408
    edited August 2010
    the newer hi res formats will onl have analog out or hdmi, they do this to stop piracy
    where have you been for ummmm like 6 years lol
    it started with SACD
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2010
    If you blink things will change. Just remember....
    It's BETTER!
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2010
    Coax is still available on most DVD players.
    As for why, high-res formats = analog out or HDMI.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    treitz3 Posts: 18,316
    edited August 2010
    WAAAAAAAAAAaaaaaaaaaaaaaaaaaa!!!! :D
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2010
    I think even analog is slated to be removed in the near future for hi-res output.
    edited August 2010
    Uh-huh. Analog has way to many aspects of the video and HI-FI outlay for the manufactures to completely abolish. I call Shenanigan's.
  • acmf74
    acmf74 Posts: 936
    edited August 2010
    I know that SACD isn't supported through a digital coaxial. It it because of piracy issues or it can't handle the flow of data?
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2010
    I believe it can't handle the data flow..
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Micah Cohen
    edited August 2010
    Perfectly happy sitting in the dark watching a perfectly calibrated Pio SD-DVD player from the stone age that has an optical audio out.
    Is Optical a "bad" technology? I can't believe that a coax is a better audio carrier. Is it?
    MC
  • zingo
    zingo Posts: 11,258
    edited August 2010
    I think coax is just easier for the manufacturer, and 99% of people don't know or care about the difference. :)
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2010
    MC
    Optical is not bad technology but it had a hard time to succeed due to the cost. Optical is also a lot more fragile and prone to failure then copper.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    billbillw Posts: 6,185
    edited August 2010
    MC
    Actually, many do believe that digital coax is a better connection than optical. It typically has lower jitter and provides a more secure connection ( toslink does pull out too easy IMO)
    Of course, if your trying to isolate electrical noise or a ground hum, then its a different story.
    BTW, many of the manufacturers are completely dropping SD-DVD players and are only producing BluRay players. I have seen some of those with optical connections (the Oppo 80 has it, as does the Panny 60)
    For rig details, see my profile. Nothing here anymore...
    edited August 2010
    I can't go so far as to say that it's bad technology but from experience? RCA [not coax] is the way to go. Why? The end result in sound as to what hits your ears and the ability to tweak your "soundscape", if you will.
    With optical, in my experience, you are limited to one [as I would put it] digitally edged sound. As with most things, there are attributes and there are deficiencies. Run with what you like but I will never again have an optical cable for sound.
  • Face
    Face Posts: 14,340
    edited August 2010
    With newer DAC's and quality optical and coax cables, the difference is minimal or none at all.
  • zingo
    zingo Posts: 11,258
    edited August 2010
    The strongest argument of toslink to me is electrical isolation which is why I run it on my PC music system. However, it can also theoretically run as far as you want without signal degradation also.
    edited August 2010
    I would imagine that Toshiba (link) products might feature their toslink cable hook ups for as long as they can? As said above, Panasonic also, seems to still like them?
    But the future is HDMI.
    cnh
  • Face
    Face Posts: 14,340
    edited August 2010
  • disneyjoe7
    edited August 2010
    Optical was capped at 96k I wonder if this is what killed it. I know for a fact optical could go as fast as we could push it ;) But saying this I wonder what we consumers would do if they upgraded optical speed making the old no workie. Look how we began to feel about all the HDMI variations they seem to come out every so often to mess with us.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Micah Cohen
    edited August 2010
    Without a receiver with HDMI-in capabilities, there'd be no way to run component video out to the TV (for unprocessed video) and HDMI (for audio only) to the receiver for audio processing, correct? (Could I do something like that?)
    I think HDMI is really getting on my nerves.
    MC
  • FTGV
    FTGV Posts: 3,649
    edited August 2010
    zingo wrote: »
    Many DAC's have pulse transformers at there 75ohm coax inputs which afford them essentially the same level of isolation from ground loops etc.
  • TECHNOKID
    edited August 2010
    treitz3 wrote: »
    Odd, from what I've read and IMHO RCA was the worse, most unreliable connector of its time. The only reason it was chosen is simply because it was cheap. IMHO BNC would have done a much better job and would have been a lot more reliable than RCA but cost was an issue. If optical used the same type of connector as what is used in proffessional installation or equipment, RCA would be long gone. Again cost is the only reason for optical cable with proper connections for not being widely used.
    Zero wrote: »
    Optical isn't a bad technology at all. I don't have any definitive answer on the topic. All I can do is 'guess' that the reason is two fold. 1) HDMI has largely replaced Optical cables. 2) Its cheaper for a manufacturer to produce a piece that uses one type of digital output. Optical introduces yet another circuit that must take a digital signal, convert that to light, then the other component must reconvert that signal back to digital, until finally converting it back to analog.
    Dunno, thats my lamens guess.
    That is the keyword; CHEAPER!
    cnh wrote: »
    cnh
    Face wrote: »
    I like the idea however, again an unreliable connector (in this case the connector locks and while this is a good thing the leaf spring action from the female connector will loose its effectiveness over time).
    If toslink was using good quality connector for home product, IMHO there is no doubt of its effectiveness and reliability.
    Below is a quality connector I remember when fiber was introduced in the military.
    Obsolete Connectors
    SMA
    Amphenol developed the SMA from the "Subminiature A" hence SMA, microwave connector. The model 905 had a machined ferrule exactly 1/8 inch in diameter that mated in a machined adapter. When the adapters were not precise enough for better fibers, a necked-down ferrule that mated with a Delrin adapter for better insertion loss performance. These connectors are still in use on some military and industrial systems.
    http://www.thefoa.org/tech/connID.htm
    DARE TO SOAR:
  • jefcully
    jefcully Posts: 4
    edited August 2010
    First let me clarify a few things for you. The optical output is capable of carrying at least 5.1 audio channels (the .1 is your subwoofer in the reality of his 6-channel audio, actually). The same goes for digital coaxial cable capable of carrying at least 6-channel audio. The difference between the two is that coaxial digital signal carries a digital electronics (two voltage levels - 1 or 0) to multi-channel receiver. With optical, it does not carry an electronic signal or analog of any transaction, or digital instead it carries a laser light beam of high freqency intensity trends as a function of the sound wave. Once you receive the multichannel optical signal, then converts it into a cable box signal.your electronic obtained optical audio output to connect directly to the receiver multi-channel, cable TV is not going your video cable (DVI, HDMI , Component, S-Video, Composite, Coaxial). If you connect HDMI make sure you turn the TV speakers turn your TV volume to a minimum since the HDMI carries sound as I said well.What above applies to all sources 5.1 output even your DVD player with speakers or television optical digital.Your not give your Dolby Surround Sound, so its useless to include the TV for audio. Hopefully it disappears.
    edited August 2010
    TECHNOKID wrote: »
    Hold on. Stop right there....What? Are you kidding me? Please tell me you are kidding.
    Do you have any actual experience to back that up?
    tonyb Posts: 32,906
    edited August 2010
    Ha...Micah bailed on this thread allready and you guys are still pissin' in the wind over RCA's.
    Tom...school that boy will ya please.
    VR3 Posts: 28,020
    edited August 2010
    BNC is a far superior connection to a RCA - it goes in and twist lock - no pressure needed to keep it in and just reverse it to release.
    Just like NL4 is far superior to a standard 1/4 jack
    Optical out DVD player? Ever heard of a XBOX 360?
  • Face
    Face Posts: 14,340
    edited August 2010
    BNC and XLR are both vastly superior than RCA.
    VR3 Posts: 28,020
    edited August 2010
    Face wrote: »
    I forgot about XLR, XLR smokes RCA
  • TNRabbit
    edited August 2010
    treitz3 wrote: »
    Tom, I agree with him.
    BNC should have been THE connector of choice.
    TNRabbit
    Sunfire TG-IV
