New binding posts for my SDAs
fbm211
fbm211 Posts: 1,488
edited July 2010 in DIY, Mods & Tweaks
I picked these up on audiogon last week and finally got them.Now Im just waiting on some silicoln to make sure their air tight after I install em.
I hope I dont have to remove the PRs to install these since I already did the moretite mod.:eek:
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited July 2010
    Congratulations on your new binders :) I'll be replacing mine on 2B's soon, so will be very interested to hear how your change goes. I went with these.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Did you get those at sonic craft? Are those cardas?
  • helipilotdoug
    edited July 2010
    fbm211 wrote: »
    No they are Vampire Wire BPHEX/CB.
    http://www.vampirewire.com/pc-49-16-bphexcb.aspx
    The price is for all 4 binders for 2 speakers.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • Face
    Face Posts: 14,340
    edited July 2010
    Both are excellent posts.
    F1nut Posts: 51,674
    edited July 2010
    Do not use silicone, it's highly acidic in the curing process. Use hot glue.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Got ya,I didnt know that.Ill order a gun and glue today.
    Thanks for the heads up.
  • decal
    decal Posts: 3,205
    edited July 2010
    Don't order a glue gun,go to wallyworld or ratshack.
    Toolfan66 Posts: 17,981
    edited July 2010
    Vampires are nice but my fav's are Cardas, and they cost less.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited July 2010
    While I'm new to all these mods, isn't $125.00 extreme? I don't mind spending the coin, but couldn't one buy an above average post and put the saved funds towards a higher level cap, resistor or any other piece?
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
    F1nut Posts: 51,674
    edited July 2010
    Gordon, if you think Cardas posts are expensive, price some TOTL WBT's.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Damn.I now find out I need to make the binding posts holes bigger in the terminal cups.I will borrow a drill and bits since my dremal doesnt have bits large enough.
  • helipilotdoug
    edited July 2010
    fbm211 wrote: »
    Hey fbm211, could you please take some photos as you do this mod, and post them on here? I'll be changing the binders on a set of SDA 2B's when I get them, and your photos of your project would certainly help me. :D Thanks
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • zingo
    zingo Posts: 11,258
    edited July 2010
    It's a pretty easy process, unscrewing/desoldering the old ones and ****/soldering in the new ones. However as posted above, I've had to open up the mounting hold a little on all the Polk speakers I've installed new posts on.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2010
    I'm not sure who you're buying them from....you can usually find them both within a $1.50 of one another depending on where you get them. There's zero sonic difference so buy what's cheaper. Both are excellent upgrades to the brittle plastic, stock binders.
    www.vampirewire.com
    I've also not had to modify the holes for Vampire's(BP-HEX)....as someone mentioned that previously. They are drop in replacements.
    WBT is horribly overpriced.
    edited July 2010
    I will take some pics of mine installed tonight..
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    dorokusai wrote: »
    www.vampirewire.com
    Killer site doro.Very fair prices too.
    Nice bananas.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    The UPS driver didnt leave the sonic craft order at my door today.I cant replace the IC posts till I get that box with all the goodies in it.
    Pics of some progress later perhaps.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Its only waiting on the cardas pure copper posts from sonic craft:D
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Pretty easy.Now to strip and bare the wire and solder to the Pods.:eek:.ETI reccomends I put a banana plug in the one Im soldering to act as a heat sink to protect the plastic..
    One wonders if I should replace the stock wire with some neoteck 14 gauge teflon copper.I think from posts to xover a 14 gauge is fine but the wires going from xover to drivers should remain the same gauge which I think is 18?????
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Look at those old posts.Are they made of steel or nickel.??:mad:
    edited July 2010
    These pics are in my 1.2tl upgrade thread as well, You can see I added a 1/4" thick piece of delrin to the back of the cups for extra support when I tightened them down.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    stopped in my tracks.I need more power --watts-- .Had to order a weller therma boost gun which should do the job.
    The 25watt and even a 60 watt I had but forgot about cant get those posts hot enough to get a good solder joint.
  • helipilotdoug
    edited July 2010
    dorokusai wrote: »
    Thanks for that information. :D Good to know the Vampire BPHEX binders are a drop in replacement.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited July 2010
    Larry, as usual a beautiful job! Thanks for posting those photos. One thing I had not yet considered doing is upgrading the interconnect. Might as well order one more set of binders to take care of that while I'm at it.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited July 2010
    fbm211 wrote: »
    MORE POWER!!! :D Thanks for posting the photos. So you are replacing the wires from the binding posts to the crossover?
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Id like to---there is some serious oxidation. And what about the molex plugs? Can I get those anywhere?
  • dbaldus
    dbaldus Posts: 730
    edited July 2010
    How are you guys getting all of that glue off? Are you just cutting it out or do you melt it and then scrape it off or what?
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • dorokusai
    edited July 2010
    I use a set of dental picks from Home Depot to pry it off. It's usually so old it comes off very easily and in big pieces.
    DO NOT MELT IT....there's no need to do so.
  • dbaldus
    dbaldus Posts: 730
    edited July 2010
    Hmmm... this makes me want to tweak my own, but I am using the blade/blade version of the IC socket on my SDA SRS Originals, so I think it may be slightly different.
    If I were to get the IC socket off (again, the blade/blade version), could I just replace it with a standard binding post and then solder the wires leads inside of the cabinet to the post? I'm a bit confused because there are two wires going to the socket right now (one to each blade), so I don't know what to do with the wires.
    I've always wanted to do this, but this is where I get confused and stop!
    2-channel
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    MOLEX PLUGS......ANYONE????
    Would old 3 wire plugs---molex---From old PC cables they use from the power supply to the HD for example.Would they work.?
    Or can I buy them.Id hate to have to direct solder from posts to xover.
