SDA 1C's Getting Better and Better
Hypnotoad
Hypnotoad Posts: 44
edited June 2010 in Vintage Speakers
I purchased some studio 1C's a several months ago and after trying different amps and some tube rolling on my Tube Box II, I settled on what I found to be a satisfying configuration.
The strange thing is they are sounding better and better, the more I listen to them. :confused:
I was impressed with these at first but I get goose bumps when I listen to them now, which is quite often.:eek:
I pulled some of the drivers to check them out and they have that gray caulking stuff in strips all over them.
I haven't checked out the crossovers. I got the speakers in the original boxes and packaging from ebay but I know the seller was a member of Polk Forum.
I couldn't be happier with them and I am glad I didn't go the Martin Logan route I was toying with.:)
ProJect Perspective II Turntable & Benz Micro Ace
ProJect Tube Box II & Philips/Amperex tubes
Luxman L-430 Integrated
Polk SDA 1C's
Post edited by Hypnotoad on
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2010
    The gray caulking sounds like mortite. I've had mine nearly a year and the wow factor has not diminished one bit. Perhaps yours had some new drivers installed and they are now fully broken in, or perhaps you are just getting used to the delicious sound the 1C's offer. Enjoy!
    Kelvin
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • dane_peterson
    dane_peterson Posts: 1,903
    edited June 2010
    Sweet! I like the Studio SDA-1Cs. Would be curious to see what the crossovers look like, though that's not as easy with these as other models. Have yet to even hook up my 1Cs... from what I hear they're quite incredible!
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited June 2010
    The fact that they get better and better sounding is interesting.
    I would pull the XO's. Since they where moritied the owner def. knew a thing or two.
    I would think that he would have mentioned the modded XO's.
    Def. worth the upgrade.
    What tweets do you have in them ??
