Center image smearing on 2.3TL's...
nooshinjohn
I was wondering if anybody else has had this problem with the large SDA's. The trouble simply put is that although the speakers sound fantastic overall, the sound that comes from the center area of the soundstage(vocals or instruments) are fuzzy at best and on poor recordings, are smeared and deeply resessed in the soundstage.
The placement of the speakers appears to NOT be the cause as I have tried them in several positions. Currently they are 8" off the back wall, spiked, and 3'4" off the side walls with exactly 6 feet between them. The listening position currently 7 feet from the front of the speakers, but at all distances, whether 5 feet or ten feet, the center images and blurred. All drivers are functioning perfectly, as are the SL-3000 tweets. The crossovers are stock.
I have upgraded to a Rogue Audio Perseus Tube Preamp, and this has helped somewhat, but I still lack cohesiveness in the center.
Any ideas here guys?
Post edited by nooshinjohn on
Have you checked the wire hook-ups on the mid-woofers?
I had one wired wrong on one of mine. I was informed by a friend that saw it was pulsing in when the rest were coming out.
I noticed yesterday that I had a pos. speaker wire not even attached to my amp. The balance was a little more to the left and the sound was ok BUT not quite right. I had a little trouble with that wire a week ago moving things around and so I thought about looking in the back and sure enough, the pos. was just floating in air but the speakers played pretty well.
But when I put it back in....BAM...pure clarity again with dead on center stage vocals..
Good luck to you finding your weak link.Most people just listen to music and watch movies. I EXPERIENCE them.
I have verified all connections at the amp, speakers and the interlink. Internally, all appears good there as wellThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Very interesting John. The center stereo image is the strong point of my smaller SDA-1C's.
Do you notice this same situation with well recorded CD's? -
Yes... It does not matter what material or source I use. It is always present to some degree.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Get some better speakers.:)
I'll take 'em off your hands for $100 and part them out if you want..........
Maybe a bad cap in your x-overs? Mine sounded better the further apart I put them about 8-9' right now.
My foot.... your ****.:p;):DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I cannot get them any farther apart right now than where they are, and I have given thought to the crossovers being the likely cause. I was hoping someone here has experienced what I am talking aboutand could say definitively what they did to solve the problem before I toss $300 bucks at crossover mods and another $300 at RDO's.
:cool: The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
maybe bigger isn't always better.................speaker wise that is
Did you have a solid center image with any other speakers?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Those are things you should have taken care of before going through different pieces of gear to find better synergy. Bite the bullet already!nooshinjohn wrote: »before I toss $300 bucks at crossover mods and another $300 at RDO's.
:cool:
FYI, upgraded crossover parts can improve imaging."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
My LSi-15's are better in this regard, but the 2.3s are better in everything else.Those are things you should have taken care of before going through different pieces of gear to find better synergy. Bite the bullet already!
I am leaning towards that sentiment as well, but am hoping someone with experience with the upgrades can confirm this will make a difference for the problem I am experiencing.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
This might sound crazy but, on some music, the SDA cable,,, just messes with it.. On some LP's or cd's I unplug the cable and it all comes back. While I do love the SDA effect, on some recordings it kind of kills it or makes it almost sound like it is out of phase in a way.. Hard to explain.
On a different note, what kind of CD player are you using? I have a friend that is running 1.2's and a theta dac and he was running some kind of time align jitter unit, .. Well, it sounded terrible on the SDA's the sound stage was off and just didn't sound right... Took the jitter unit out and the time thing and just ran it with the DAC problem solved.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
It's not the design of the speakers and your set up is spot on, so I'd check for weak/bad tweeter(s) and/or crossover issues.Political Correctness'.........defined
President of Club Polk -
Absolutely and absolutely."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
What does one use to check a cap and/or resistor?
An LCR meter."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
A digital multimeter should work too.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
You need an ESR meter to check the caps as they are in the circuit and operating. Just taking a cap and putting it on MM won't tell you anything.
see this post.
http://www.polkaudio.com/forums/showpost.php?p=1332336&postcount=5
Just replace the damn things, they most likely need it anyways. Do the RD0's as you have funds."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
My 2.3TL have perfect center imaging and I have yet to do tweeter and crossover upgrades.
Check your crossovers. If you have an issue with mid recessed imaging, You may have defective crossovers.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
It won't most likely read caps. You need a special meter to read inductance and capacitance. None will tell you sound quality.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks for all the support guys. This place is the best!:)
I did some homework, with the information you guys provided, and decided the crossovers are the place to start. The most annoying part of the original crossover is no doubt the polyswitch, so I bypassed the switch using the method suggested by Ben(thanks for the call bro) and reinstalled the crossovers.
Imaging problem SOLVED!!!
:D It is as others have said countless times before. The veil has been lifted and the difference in clarity is night and day. If the crossover upgrades are anything as dramatic as this, I will be sending them out by the end of the month!:D The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
John IMO you have waited too long already.. My 1.2's only had about an hour of playing time before I tore them down for the upgrades, as well as my 1C's.
I love ya bro but get it done already.... -
^^^Lol, yes SIR!
I am saving the coin for them now.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Am I crazy for thinking the harshess has been deminished from the SL3000's by removing the poly's???The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
WTF, weren't the 1C's you sold Dave modded? If so, you should know how dramatic the change is."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
The poly's were still in place on those...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
It can tell you if it is either shorted or open,and some meters like my Fluke 175 can measure capacitance.Just taking a cap and putting it on MM won't tell you anything. -
Crossovers & RD0 upgrades are what will take care of this "issue" John.
