Good pre amp for parasound 1000a
cnoat
cnoat Posts: 315
edited September 2011 in Electronics
Can anyone recommend a good pre amp for a 1000a.Just picked one up and it is great.Just think it could be better.
Thanks in advance.
Steve
Parasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC
Post edited by cnoat on
  • niles300z
    niles300z Posts: 21
    I can tell you I am using a B & K Pro-5 and it is quite a decent combination.
    I like the option for a passive mode on the preamp that can smooth out some digital recordings.Otherwise, has good gain.The Pro-10 is supposed to be even better with better jacks and a separate power supply. I have tried a few and I may try a Parasound if one pops up for a decent price. I think sometimes brand similarities help a bit. I aim for neutral and like a tone bypass if possible. It seems the older Yamaha are well thought of as is the Apt Holman for vintage stuff. Sorry for the tardy reply.:biggrin:
    Niles
  • brgman
    brgman Posts: 2,859
    what kind of pre are you using now?
    I’M OFFENDED!!!!
