Vibrating Mid Range Speaker
Coach P.
Coach P. Posts: 6
edited March 2003 in Troubleshooting
I own a pair of SDA 2A's. Most recently, I am getting noticeable and unflattering vibration from only one of my two mid-range drivers in the right speaker.
Do I need a new driver? If so, what is the best way/least expensive way to obtain a new one?
If I don't need a new driver, what do I do to solve the problem?
Post edited by Coach P. on
  • mantis
    mantis Posts: 17,056
    edited March 2003
    It sounds like it's worn out.Polk has replacement drivers.
    I would replace both drivers in both speakers,if you plan on keeping them for awhile.Fresh new drivers......cool.
    Dan
  • Coach P.
    Coach P. Posts: 6
    edited March 2003
    :) Thanks Mantis. I appreciate the prompt feedback. I've contacted Polk and will have a new driver soon.
