Amp Box
eloplayspolo
eloplayspolo Posts: 1,117
edited October 2007 in Custom Fabrication
K so im thinking of building an amp box or rack to go under my sub box in my trunk, i was thinking of laying it flat and placing the amps side by side, i was wondering how much air flow i would need for them
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
  • Installer4life
    Installer4life Posts: 256
    edited October 2007
    Your MTX amplifiers have built in fans to help keep them cool. Just make sure they are able to draw in air. You could probably get by with 1" of space between the top of the amp and the bottom of the enclosure. Just make sure they can draw air in from both front and rear sides of the enclosure. Obviously if you can give them more room then do it.
