Speaker compatibility with SDA-2B's?
Hi,
I am thinking about upgrading to a 5 speaker home theater surround. I would like to keep my two front speakers if possible. They are Floor standing Polk SRS SDA-2's. I would need a Center channel, and the two rear speakers. Can I get them to be "compatible" or system matched for sound with my current speakers, or do I really need to purchase a whole new set?
Any replies would be helpful
Thanks,
Mark
Thanks,
Mark
Post edited by jacobsrph on
I am going very high end on the amp - 300 watts X 5 channels into 8 ohms, 600 watts X 5 channels into 4 ohms. I realize that my SDA-2's are 6 ohms. Are the LSi's at a different ohm rating, and is that a concern?
Mark,
I bought SDA2's a few months ago and was using them
as my fronts. I put together a HT setup and bought
SDA1'C-s as my new fronts, moved the 2's to the rears,
bought a CS400i center channel and a psw450 sub.
I'm very happy with this setup!! If you could find a pair
of 1-C's or another pair of 2's, go for it. I think the cs400i
is a good match. There is another center channel that is
supposed to match up well with the sda's, I think it is
def tech or something. Someone here will know. SDA's
make great ht speakers IMO. The new dts Lord of the
RIngs rocks my house!
MIkeFronts: SDA1C's
Rears: SDA2's
Center:CS400i
Sub: PSW505 -
I agree...the SDA's are a good HT speaker. I have a CS400 center that matches well with my SDA-2Bs. I also have a pair of rt1000i's for the rears. I have a PSW350 for the sub. I like it a lot. I have also heard the fx500's are a good match for surrounds with these speakersHome Theater
Sony DA7ES 7.1 A/V Receiver
Sony DVP-NC80V - SACD/DVD player
CS400 - Center channel
RT2000i - Fronts
RT1000i - Surrounds
a/d/s MS3/u - subwoofer
Hitachi 62 inch HD TV
2 Channel Room
Niles HDL-4 Speaker Selector
Niles HDL-6 Speaker Selector
Sony V555ES receiver
Sony DVP-S7700
Polk SDA-2B
Polk Monitor 5
Thiel 03a
B&W 2001 ZMF
Signet SL-250 B/U
a/d/s L400e
Wharfedale Valdus 100SE
Polk PSW 350 - subwoofer
Pioneer Elite Big Screen
