New Def Tech tweets on E-bay
jrausch
jrausch Posts: 510
edited November 2002 in Speakers
There are 5 pairs of new Def Tech tweets for sale on E-bay. $35-$40 per set. 1" pure aluminum Moving Coil dome tweeters spl;92db very similar in sound to the SL3000's. Would probably make better replacements than the new stock versions for twice the price. Hard to get from Def Tech, unless original is broken.
Here's a link to one set that has been bid on. 4 more sets available for $40 "buy it now" Nice guy to deal with.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=800023171
"The only way to get rid of a temptation is to yield to it."
Post edited by jrausch on
  • RuSsMaN
    RuSsMaN Posts: 17,987
    Have you encorporated these into SDA's before? The only thing that bothers me is the freq response, 2800 and up. They do however show the resonant freq to be 1415.
    Aren't the SDA's crossed around 2000?
    Cheers,
    Russ
  • jrausch
    jrausch Posts: 510
    I bought a pair to do some testing with the SDA's. I will let you know if it's posible integrate them with the SDA tweets. I have a Def Tech center that works real well with 2.3's.
    -Jer
