Receiver antenna problems resolved
faster100
Well tonight i bought a RCA cheap O antenna just for kicks to see if it worked better than my 50.00 and 30.00 terk antenna's. Well it doesnt look real cool but it brings everything in, works great and its non powered. i live in a 1940's house so everything looks old anyways, LOL doors,window frames, base boards so why not a black rca metal antenna ?? Well when people come over for movies or what not i will just push the antenna;s down, LOL
anyways they work and k-mart had it on sale for $7.99 down from about $15.00 so i even got a good deal. well that saved me about 100.00 bucks buying a used receiver or antenna. Thanks for whoever told me to try the RCA rabbit ear type antenna.
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
Hey thats my wifes deal, LOL she gets the dolls on the big screen i get the audio stuff i want. works out good that way.... I know i know..... But the antenna... works great!! I know its not a million dollar specialty one but hey some times more doesn't mean better.. Thanks i will let my wife know you like them.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Thats the thing that counts........it works....you know if you have an attic above,you could stick that thing up there.Just run the wires down inside the wall and plate it behind your equipment.Then you won't have to look at it.Dan
Hello Faster This is StuffMD...I am the RCA antenna suggestion guy...I am glad it worked out for you....I am so pissed in all the money I spent on these so called trechnology antennas to get crappy reception.Terk especially...I bought the RCA for tv one day and read it it also works on FM as well and couldn't believe the reception difference....Next step if you have an entertainment center, my unit had holes to hang the unit..it will work behind the center .....................just takes a little more adjusting....
Happy Stereo...Peace, StuffMDYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube
