where to install speakers on the wall??
faster100
faster100 Posts: 6,124
edited September 2002 in Speakers
Ok i asked this question but only got one response, which is great but now i have read other posts where the rears position being at ear level or just above wasnt good?? My rears are just about right at ear level or a few inches up and when i sit on my couch in the center of the rears they are about 6 feet or so away on each side so should these be higher or stay where there at? Let me know so i can make some changes or not. Thanks
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • organ
    organ Posts: 4,969
    It depends. Near ear-level gives you a more direct sound and 6ft up gives a more diffuse sound. If you sit against the back wall of your room, try facing them against the back wall at a 45 degree angle. This works best for me because mine are a little over ear-level and I sit against the back wall. The best thing for you to do is experiment because room acoustics plays a major role on how your surrounds will sound. If you don't like the direct sound but can't mount the speakers at least 6 ft, try laying them on their backs facing the ceiling. I tried that and it wasn't too bad.
    Maurice
  • faster100
    you mean 6 feet up from the floor? or six feet higher then ear level? They are like 4 feet from the floor now, so i can easily go another 2 foot up if thats what you mean, Thanks and let me know
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • organ
    organ Posts: 4,969
    Yep, you got it! Raise them to 6ft from the floor. This set up usually gives you the best sound with direct-radiating surrounds. At 6ft high, they should be facing eachothe with the sound radiating right above your head. I tried this set-up before and it really makes you feel like you're in a large theater. Try it and tell us what you think.
    Maurice
