CSi30 or CSi40?
I know the 40 is better but is it worth the extra money?
Will the 30 work well with my RT1000i's? Does the new CSi line work well with the RT1000i's?
Any info about these two centers and which one I should get would be greatly appreciated!
Thanks!
Thanks!
Post edited by tryrrthg on
The Best Match for the RT1000is would be the CS400i. It has the same tweeter and the same drivers.
Next would be the CS245i
If you can't find either of those, I's reccomend the CSi40, although the CSi30 is also a great speaker. The new tweeter in the new center speakers is brighter than the old one, that's why I'd try the older ones first. -
THANKS GuitarheadCA! I'll have to see what I can find...
Any other opinions out there?Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
